Hello,
Need this electrical diagram explained from a logic perspective. I searched elsewhere in the chapter and it only explains how to take apart things and to put it back, not what each component is supposed to do.
In particular, I need to know what the following components do:
1. geared motor what does it do?
2. brake caliper sensor - checking pad wear or something else?
4 potentiometer - don't even know where this is, didn't see any knob
6 and 7 why are 2 of them needed?
8 what kind of tester can I use?
12 why does the light switch take input from the tilt controller?
14 I assume it's a fancy name for a relay, right? same for horn item 16
15 senses what oil pressure and why
And also what's that thing a littler lower and to the right of number 14? Is it what it looks like, a push button? Is it push to close or push to open?
