@jonathan_1 avatar
Scammer
GTS 300
Scammer
@jonathan_1 avatar
GTS 300
to flush coolant, is it better to remove the three screws in center of pump or cut and replace clamp on radiator hose?
310 GTV Officina 8
310 GTV Officina 8
Robots done videos for the various engines , have a quick look on u tube. Heres the hpe
@abner_bjorn avatar
@abner_bjorn avatar
Basic coolant service...? Lower hose clamp only. Here's why. 1. the three phillips screws can be a bear to get off. 2. you only miss a shot glass of liquid by leaving the cover in place. 3. no chance of having a gasket problem if you don't remove it 4. less likely to disrupt the other two hose clamps causing leaks. The only time I pull that cover off is when removing the whole water pump housing.
[ Time: 0.0102s ][ Queries: 3 (0.0029s) ][ live ][ 343 ][ ThingOne ]
