@danthesloth avatar
2006 Granturismo 200L
@danthesloth avatar
Looking for
Turn signals that automatically turn off in 15 to 30 seconds.
Sorry if I missed a solution already posted.
Slow roller
Sloth Dan
@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
@danthesloth avatar
@danthesloth avatar
Thanks. I will look into this option.
@mitleider avatar
2024 GTV & 2024 GTS Supertech
@mitleider avatar
Does anyone have experience with installation; i.e.is it DYI....or require soldering,splicing,extra fuses etc?
Couldn't tell either if product compatible with US market 2024 GTS/GTV 300s...??
Thanks for chiming in with advice!
@danthesloth avatar
@danthesloth avatar
Good questions. After entering bike model and year details website indicates, it will email you to tell youif your bike is compatible. Then it just takes you to a checkout page to purchase. So it's unclear if it will work.
@kawzak avatar
New 2023 BV-400
@kawzak avatar
New 2023 BV-400
I bought a self cancelling unit for my ( USA) 2016 GTS in 2017 ( I think) from Scooter west. I installed it without issue. Pain to remove some body work, otherwise straight towards. It worked well. Timed out after turn signal was activated. I also installed an electronic flasher so I could install LEDs. Got rid of the add on/ hang on turn signals and used the running lights/ turn signal ( existing in body) for a clean look/ set-up. Like the European Vespas have.
[ Time: 0.0091s ][ Queries: 4 (0.0028s) ][ live ][ 343 ][ ThingOne ]
