CrazyCarl wrote:
The H4 halogens do tend to dim with age so they should be replaced periodically. You might consider upgrading to a LED at this time, plenty of good ones to be found on Amazon or perhaps at local retailers. You may need to adjust the aiming all the way down to prevent dazzling oncoming traffic.
I have had good luck on 2 different scoots with the Auxito branded H4 LEDs Amazon, truly plug and play, good light output and durable.
Another thing to check is your electrical system's output. Check the voltage at the battery with bike running at idle. If it's producing between 13.0v and 14.5v, you should be fine. < 13.5v indicates your stator is not producing enough power - it's likely starting to fail and needs cleaning or replacement. >14.5v indicates your voltage regulator is failing and needs replacement.
Thanks, maybe I'll change the bulbs and see then 👌🏻
