Lots of stuff here that I've collected over the years for one reason or another, but it all has to go. Pick it up if you're in Phoenix, but we can work out shipping otherwise and I will be reasonable.
Want to buy a few things together? Make me an offer. Photos of everything below.
2x vintage largeframe (VBB) kickstart lever bolts, new - $3 each
2x adapters for mounting mirrors at the pinchbolt of a vintage largeframe, new - $10 each
Cuppini left hand mirror, new - $10
1979 P200 clutch, original, needs a rebuild with new plates, but otherwise in good condition - $15
1979 P200 flywheel, original, magnets are still strong and it's in ok shape with some dings and marring around the edge, I assume from being removed with the 2-screwdriver-trick - $20
1979 P200 stator plate, needs rewiring as the originals are cracking/breaking - SOLD
SIP fuel tap with lever & grommet for 60s largeframe, new - $10
P200 kickstart lever with new rubber - $10
