I have Malossi upgear kit part# 67-5235 with 24/63 straight tooth gears for a PX style clutch. I have a banded Cosa clutch I want to use. I want to buy just the straight cut clutch gear cog to make it work without buying an entire complete new gear kit.
DRT makes a 24t straight cut Cosa gear but only lists it for use with a 62t primary.
Will this work with the Malossi 63t primary?
On the SIP Malossi description it lists DRT to make the conversion.
