@swamprat96 avatar
Vespa gt200, Vespa LX150 -onion project- every layer holds another surprise
@swamprat96 avatar
Trying to understand where the steering stops are in an LX Vespa? Are they in the tunnel that the fork is in? Are they adjustable? My LX mudguard is hitting the body on the left hand side
They are part of the steering column, not adjustable. If the mud guard is hitting the frame, either the mudguard is mis-centred or the fork has been bent backwards.
@swamprat96 avatar
@swamprat96 avatar
Hmm I suspect the fork unfortunately.
@berto avatar
2018 Liberty 150
@berto avatar
2018 Liberty 150
You're thinking that's the cause of wobbly steering? Crying or Very sad emoticon
Lx150 Vespa - wobbly steering
@swamprat96 avatar
@swamprat96 avatar
Yep I have a nasty feeling. I'm going to drop the fork out and check it as the bike is pretty much stripped down so it's not that much more work. I suspect it will be the lower section and I have an acquaintance with an engineering shop who should be able to straighten it if needed. It's made harder with that weird bump in the lower section of the fork .
I'm just hoping the upper part and the frame tube it goes into is ok because of that's not it's a write off.
@swamprat96 avatar
@swamprat96 avatar
Well good news- the fork is straight. The lower steering race was toast which I suspect was the wobbly steering- new parts ordered. With a new (used)wiring harness, Speedo, brake handles, glovebox (used) , handle bar covers (used), seat , fuel tank surround, and a ton of panel beating it should be good to go. Still in pieces right now but the reassembly starts this week.
[ Time: 0.0136s ][ Queries: 3 (0.0031s) ][ live ][ 343 ][ ThingOne ]
