Piaggio mp3 530 2023
Hey
Where is on new model piaggio mp3 530
Drain plug for coolant?
How to drain coolant?
Thank you
2015 MP3 500 ie Business
Afaik there is no coolant drain plug, but removing the water pump impeller cover accomplishes the same
2019 GTS 300 HPE w Malossi
Thanx i have see all this manuals, but cant find nothing about how to drain system.
If i remove hose from impeler (water pump) on the newest mp3 530 is the radiator on the bootom of piaggio not like old one that has it high. So if i remove hose from water pump, coolant will not drain becous radiator is lover that hose from impeler.
Vacuum bleed and refill is probably the only way then
[ Time: 0.0081s ][ Queries: 3 (0.0018s) ][ live ][ 343 ][ ThingOne ]
