@colinbelgium avatar
VBA1T/Px200 iris/VNB6T
Hello,
I wonder if something is wrong here.
There is no side hole into the VNB chassis on the side for gear cables as on a VBA for example
Should all cables go through this grommet ? (2x gear, rear brake and clutch)
Rear brake and clutch are already tight !
As I replaced the floor board, I replicated the hole where the cables are supposed to go through and added a grommet as seen on exploded drawings, but I'm not sure all cable sleeves will fit into there without battle.
Was there originally a grommet there ? If so, is there different types ? Does the one have look ok ?
Thanks !
@moto64 avatar
@moto64 avatar
All four cables run through that hole. It is tight.
https://www.scootermercato.com/Scooter-Parts/Grommets/70286
Thank you.
I have the right grommet then. Will use a bit of soapy water to ease.
[ Time: 0.0144s ][ Queries: 3 (0.0026s) ][ live ][ 343 ][ ThingOne ]
