Posts: 4815 Location: Twin Cities, Minnesota |
My 2019 Primavera's battery has died over the winter. I could replace it with an AGM, but I'm thinking this may be a good time for a lithium battery. Any comments, or recommendations for a good lithium battery? I don't want to pick a battery at random from Amazon and have it be a piece of junk.
2007 MP3 250ie / 2022 MP3 500HPE SA [Bad Ass Edition]
Posts: 531 Location: CCS-Vzla |
Lithium works fine. I'm using Noco brand in two of my bikes (HD and MP3 500) and works very well, in other bike I have a Antigravity, is very good but the price point is so high.
Noco brand looks good if I can find one in the US. Autozone possibly has them. Do you know if they come with spacers to fit in my Primavera (original battery was YTX7L-BS)?
I purchase my Nocos in amazon
From what I see, if is Noco is a NLP5 (based in your comment about the actual one YTX7L-BS), but you can confirm in the Noco web page https://no.co/lithium/powersport And yes, it come with a group of modular spacers. Note: I have no commercial relationship or business interest in Noco, I am just another user. |
Posts: 46191 Location: Pleasant Hill, CA |
You can get a Mighty Max LiFePO4 (as sold by Home Depot and many others) for ~$55, e.g. https://www.mightymaxbattery.com/shop/lifepo4/ytx7l-bs-lithium-battery-replaces-honda-250-cb250-nighthawk-1991-2009/
I ordered and installed the Noco NLP5 battery yesterday. It went in easily enough, though the ring terminals on the scooter had to be drilled for slightly larger screws on the new battery (as was mentioned in some of the reviews for the battery). The scooter started with the first push of the start button. I also bought a Noco Genius 1 charger with the battery. One thing I don't like about the charger is that it uses a connector different from the SAE connectors on my other charger accessories.
JKJ-FZ6 wrote: I also bought a Noco Genius 1 charger with the battery. One thing I don't like about the charger is that it uses a connector different from the SAE connectors on my other charger accessories. |
This charger is supposed to work with any battery. It has a switch to select wet cell, AGM, or lithium.
JKJ-FZ6 wrote: This charger is supposed to work with any battery. It has a switch to select wet cell, AGM, or lithium. |
JKJ-FZ6 wrote: One thing I don't like about the charger is that it uses a connector different from the SAE connectors on my other charger accessories. https://www.amazon.com/dp/B005DUMADC?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_5 |
Having seen the winter scenery in Minnesota , albeit through the medium of Amazons Fargo , one thing to consider with Lithium batteries is they don't like cold , so probably worth removing it in the very cold months.
The cranking power of lithium's is legendary, plus the size and weight saving is significant. |
S150 '09, Beo 500ie '08
Posts: 1597 Location: Bermuda |
My issues with lithium batteries in scooters is that they solve problems I don't have, and introduce complexities I don't need, at a higher cost.
I get 3+ years out of cheap-ish Amazon batteries that typically degrade gradually and give plenty of opportunity for leisurely replacement, a lithium jumper pack easily solves the worst-case dead-battery scenario, and that's completely fine. |
Juan_ORhea wrote: My issues with lithium batteries in scooters is that they solve problems I don't have, and introduce complexities I don't need, at a higher cost. A standard charger will work with a LFP battery. Very few riders venture out in temperatures lower than -20C (~0F). |
These and other sites suggest special "wake up sequences" begin in the mid-40°Fs.
https://www.batterystuff.com/kb/articles/battery-articles/lifepo4-lithium-iron-powersport-batteries-cold-weather-performance.html https://www.fullspectrumpower.com/blogs/full-spectrum-news/10662405-lithium-batteries-in-cold-weather Anecdotally, not clear if the set of chargers and tenders I have now will work well with them. And they're more than twice the price ($80 vs $35). Will they last 5-7 years when the regular ones last 2-3? Do I want to spend up now to find out later? Not really. More power to others who feel differently though. |
I'm going to echo the other comment, what use case does lithium help with? AGM starts the scooter fine, and lithium batteries don't like the cold and can be a fire risk. The AGM are cheap and fairly reliable if you tend them in the offseason.
xtitus wrote: I'm going to echo the other comment, what use case does lithium help with? AGM starts the scooter fine, and lithium batteries don't like the cold and can be a fire risk. The AGM are cheap and fairly reliable if you tend them in the offseason. Here's a good run-down: |
You're partially right. LFPs are much LESS of a fire risk, but they are more risky than lead acid. LFPs are much more thermally stable and combustibility is much lower than NMC.
Overcharging, short circuits, physical damage, etc are still fire risks. I'd says poor build quality of the battery or a person overcharging are the biggest risks. I work in medical devices where we design lithum charging circuits for LFPs, so I have some insight here. So, yeah, much lower if you can get a LFP and I would definately avoid the NMC (agree with you there). But lead acid is hard to beat if all you're trying to do is start a scooter engine for the price. |
