Vespa GTS super sport 125
Hi guys
I've tried fitting the rocker arm pins from my original vespa gts super to the malossi v4head but they are two small is there any recommendations to sort this issue out its doing my head in
Cheers Craig
try contacting the vendor you bought it from.
your sig says gts125 ...
some support the v4 some don't. need to be more specific
this 125 doesn't
https://www.malossistore.com/en/au/vespa-gts-super-125-ie-4t-lc-euro-4-2017-2020-vegt125s17-M
this 125 does
https://www.malossistore.com/en/au/vespa-gts-125-4t-lc-euro-3-2013-m315m-vegt125-M
Thanks for replying
Vespa is a gts supersport 125 year 2016
I want to use the rocker arms and the shaft from my original head I need some sort of bushes for the end's to stop it.moving about
Cheers Craig
unfortunately the year number is too imprecise.
what is your vin prefix (first 9 letters/numbers) and what is the engine prefix (first 5) written on the transmission case nearish the rear brake caliper?
Hi zapma45301
Cheers Craig
[ Time: 0.0077s ][ Queries: 3 (0.0018s) ][ live ][ 343 ][ ThingOne ]
