Hi. I removed the variator to check the oil pump drive belt. After putting everything back together, the scooter no longer runs properly. It starts and idles fine, but chokes/stalls when I give it throttle.
From what I can see, the belt sits deep near the variator axle (front pulley) and far out at the rear near the clutch. The stalling seems to begin once the belt starts to tighten at the front pulley. It also looks like the belt pulls in at the rear, but maybe not completely in toward the clutch shaft.
For the record, I don't have any leftover parts, so nothing seems to be missing. I'm also confident that the rollers and plastic guides are installed correctly.
Has anyone experienced something similar or have any ideas on how to fix this?
