ArnoEn wrote:
Have you tried to pull out the fuel injector and check the spray patern?
To check if there is fuel.
I recently had an intermittently failing ingnition load relay. This relais powers the fuelpump, injector and ingition coil.
The engine stumbled during the ride, some times would not start at all. And moments later everything was ok again.
Maybe you have the same issue?
Engine Stalled during ride
I don't think that's the Problem I have, because mine doesn't stumble or quit running after 30 seconds or so. Mine dumps Fuel by first start of the Day, but if and when it finally gets up to Running Temp.,it runs like a Charm and doesn't smell like it's Farting gas Fumes out through the Exhaust Pipe. It has never done this before until recently.
Thanks for Input ArnoEn. If you or anybody else has any Idee what may be causing this, Feedback would be most Welcome.
Thanks again from the Hillbilly
P.S. The Injector is original Piaggio and it's brand-new.
