Hi all. I've got a 2005 Genuine Stella 2T that I am having issues with the front end. The damper finally let go, so it was time to replace the front shock, plus needed a front disc brake bleed plus new pads.
The new shock installed without issue. The issue is with the brake: upon re-installation, I see that my front caliper is not centered, but offset to the left side of the disc (inboard/driving position) by maybe 1.5-2mm. It's offset to the point that the brake pad pin contacts my tube valve at the bend. There is no play in the front hub. I am replacing pads, the pistons have been re-set into the piston pocket fully- it's the caliper that's offset, which is weird because it's a fixed position caliper and should not be this far inboard, especially when mounted directly to the caliper holder plate. It may have been like that from the onset, but it's now weird that the brake pad pin is contacting the valve...
It came stock with the red Bitubo, and I am replacing with the black coil set from Scooter Mercato: https://www.scootermercato.com/s.nl/it.A/id.11951/.f if that makes any difference.
Anyone come across this one? Next step is to remove the front hub and make sure the proper spacers are installed, but wanted to troubleshoot/investigate before I get too unnecessarily in the "take it all apart" hole.
