Hi guys,
until today my handbrake worked very well - I replaced the bowden wire two years ago because the rounded ending on the lever side broke. And I had no issues until now. Today I noticed that the lever doesn't go all the way up. It gets stuck half way up. The bowden wire moves freely, so it's not pinched or anything. And at that point the wheel is actually blocked (doesn't move), so everything seems to be working ok. The nut at the end of the bowden wire (wheel side) is not loose, so it couldn't have moved or readjusted itself. If I loosen it and screew the adjuster all the way in, the lever goes a bit higher before stopping. So it looks like the caliper grabs the brake disk too quickly. As if something came between the cylinder and pad or something... Has anyone else ever had a problem like this? I think that it must be something wrong within the caliper.
Thanks in advance!
