Sportcity Cube 250 IE
Hello. I am having a hard time finding information about LED signals on scooters and am hoping someone here can point me in the right direction.
I am trying to replace broken signal with new LED turn signals on my 2009 SC250ie and find myself needing some help. I have two sets of inexpensive TEMU turn signals. One set has three wires and the other has two wires. The two-wire set matches the original two wire setup on the scooter so I was thinking this should be a simple install. I hooked them up and they will turn on and are very bright but not flashing. Goggling around, I have found that a diode may be needed or a different flasher relay. I am hoping someone here has done this and can point me in the right direction for what I need to do to get them flashing. I only test fitted one signal. I am wondering if I have to install them all to get them flashing?
I have also searched for the relay location. I haven't found that either. I did find an old post that for a MP3 and says it may be under the foot rest. I am hoping not to have to remove the plastics. That looks to be a project by itself but I am all in.
About the set with three-wire setup. It has a white/yellow and can set up to have continuous bright white running lights and the yellow turning signal. I really don't know how to go about using this setup but it would be nice and seemingly safer. If someone has some insight, please let me know. I actually would rather have the running light feature.
Thank you in advanced for any help you can offer.
Moved from NSM to General Discussion, as Sportcity is not an NSM scooter.
[ Time: 0.0072s ][ Queries: 3 (0.0015s) ][ live ][ 343 ][ ThingOne ]
