![]() I have a few scooters....
Posts: 2225 Location: San Antonio, TX |
Thu, 10 Nov 2005 04:34:46 +0000
Has anyone upgraded to the Malossi 210cc kit? Is it worth it for the extra 10ccs? Also will there be a 250 or 275 kit coming with the introduction of the GTS? Thanks in advance for info.
Thu, 10 Nov 2005 04:40:02 +0000
i know of three 210cc kits installed in the states
Josh from Scoot! mag ScooterBobby from Vespa SB myself & Big Jim @ WetSpeed should be installing his soon ScooterBobby is running the best & he is using the stock jetting in the euro carb Josh & i were jetted with a 105 main jet & bgging out big time (stock GT's could out run us) im down to a 100 main jet & things are better but not like bobbys As far as kits for the GTS ..... Malossi makes a 290 kit for that 250 master motor but i dont know how you go about re mapping the fuel injection |
![]() Thu, 10 Nov 2005 06:31:07 +0000
Vespa GT & Vespa LX
Posts: 517 Location: Southend-on-Sea, UK |
![]() Vespa GT & Vespa LX
NapaCoach wrote: As far as kits for the GTS ..... Malossi makes a 290 kit for that 250 master motor but i dont know how you go about re mapping the fuel injection |
Thu, 10 Nov 2005 06:51:19 +0000
now its making sence
i thought that honda 250cc foresight motor was renamed QUASER & the malossi kit would work i feel pretty fucking dumb did the foresight motor use a carb ? |
![]() Mon, 14 Nov 2005 17:58:08 +0000
Peugeot Looxor
Posts: 3220 Location: KCMO |
![]() Peugeot Looxor
Not sure if the 250's crank case is the same as the the 200, but the 250 crank is a longer stroke than the 200. The barrel and piston are the same size for both. If the crank case is the same, you could get a 250 crankshaft and the 290 barrel and piston, and cobble up a 290 motor.
Sir Frets-A-Lot
![]() Vespa GT250ie/L, Honda Ruckus 50, Honda NT700V, Honda CB125
Posts: 11197 Location: Bee eff eee. |
Mon, 14 Nov 2005 18:17:54 +0000
man! M@'s GT can definitely keep up though! Quick as lighting. Every time he'd start off I'd hear the "Speed Racer" theme in my head...
Mon, 14 Nov 2005 21:54:22 +0000
i sure hope some one with a white scoot uses the SpeedRacer theme
just get some stickers or paint to make thier bike look like Mach 5 ![]() matching helmet ?? |
