Hey guys, mid engine rebuild here. To be honest I want to skip the step painful step of figuring out my crankcase volume, its quite modified for reed valves. So I'd like to know if anyone out there knows the crankcase volume of a PX150 crankcase or anything close. Thanks in advance 🫶🏻
Innovator
Posts: 12964 Location: Nashville 283 Days Since Last Explosion |
Innovator
danielbrucee wrote: Hey guys, mid engine rebuild here. To be honest I want to skip the step painful step of figuring out my crankcase volume, its quite modified for reed valves. So I'd like to know if anyone out there knows the crankcase volume of a PX150 crankcase or anything close. Thanks in advance 🫶🏻 And how accurate are you trying to get here? Figure the crankcase area is ~7700 mm^2. Multiply that by depth of the crankcase, less the cranks' volume (volume of the cheeks * 2). Then, add the area of the piston * stroke and that's probably pretty close. |
Posts: 1202 Location: York, PA (the intellectual center of the universe) |
Fluid Displacement -
Remove cylinder and piston from the engine. Seal all ports/openings. Position the crankshaft at Bottom Dead Center (BDC). Fill with a light oil ensuring no air pockets. Measure the total volume of oil used with a graduated cylinder. |
chandlerman wrote: Out of curiosity, what are you planning to do with that knowledge? And how accurate are you trying to get here? Figure the crankcase area is ~7700 mm^2. Multiply that by depth of the crankcase, less the cranks' volume (volume of the cheeks * 2). Then, add the area of the piston * stroke and that's probably pretty close. |
garncarz wrote: Fluid Displacement - Remove cylinder and piston from the engine. Seal all ports/openings. Position the crankshaft at Bottom Dead Center (BDC). Fill with a light oil ensuring no air pockets. Measure the total volume of oil used with a graduated cylinder. |
P Series / LML / Motovespa
Posts: 1642 Location: UK |
You could use gasoline if you like playing with combustible liquids and can do it in a well ventilated area. Not recommended due to the safety risk
I also point out a couple of modifications you will also need ro make to the setup as the current setup is very restricted in terms of gas flow See attached image
Positive
Jet Eye Master
Posts: 5383 Location: London UK |
I was just thinking the only place I've seen work like that is Indonesia, then I saw your profile.
Crankcase volume is not such an issue. Interesting to measure but generally it is too small for a 187. Using a full circle crank will make more maximum power. Using a bell crank more mid range. Whatever crank you decide, the biggest easy power gain I would do is cut the bar from the cylinder skirt.
Positive
Gravelrash2004 wrote: You could use gasoline if you like playing with combustible liquids and can do it in a well ventilated area. Not recommended due to the safety risk I also point out a couple of modifications you will also need ro make to the setup as the current setup is very restricted in terms of gas flow See attached image
The top down view should look something like this when done
⚠️ Last edited by danielbrucee on UTC; edited 1 time
Positive
Jack221 wrote: I was just thinking the only place I've seen work like that is Indonesia, then I saw your profile. Crankcase volume is not such an issue. Interesting to measure but generally it is too small for a 187. Using a full circle crank will make more maximum power. Using a bell crank more mid range. Whatever crank you decide, the biggest easy power gain I would do is cut the bar from the cylinder skirt. |
Jet Eye Master
danielbrucee wrote: Ive been thinking about cutting the cylinder skirt, but is that risky at all? I have 2 of the same blocks, one with the durations changed a bit for drag and dyno but i still sometimes use it on the road for events or touring. Im worried about piston life. Piston lives matter 🤣 Be really careful about detonation or running overly rich. Both put pressure on that area. |
Posts: 10154 Location: Ballarat VIC, Australia |
Some time ago I had a Polini 208 and found (when looking at another issue) that the skirt had cracked. I cut out the window where the crack was and next time I rode it it seized. The skirt had sprung slightly inwards. So many problems with that cylinder!
I wonder if you could just reduce the width of the bit in the way of the gas flow? |
Ginch wrote: Some time ago I had a Polini 208 and found (when looking at another issue) that the skirt had cracked. I cut out the window where the crack was and next time I rode it it seized. The skirt had sprung slightly inwards. So many problems with that cylinder! I wonder if you could just reduce the width of the bit in the way of the gas flow?
Yesterday finally got it all together and running, will say its running like a beauty. Before all that we did get to fill the crankcase with diesel. My goal was for a 1:5 ratio to engine cc. Which would be 280.5cc using the 187cc block. Well we ended up with roughly 295cc, we couldnt get an accurate measurement due to my reed valve leaking and just being lazy to wait for new reeds. We ended up just blocking off the reed all together then trying our best to calculate the volume of the inside of the reed valve and subtracting it from the total measurement.
what is the result with the optimum volume? What are you improving? are you needing to increase or decrease the volume to achieve the desired goal?
hibbert wrote: what is the result with the optimum volume? What are you improving? are you needing to increase or decrease the volume to achieve the desired goal? |
xperimental21 wrote: Curious.. what is the benefit of having a such modified intake? |
Took her out for a test run today, ill say she scared the shit out of me. Getting prepared for a dyno event next week but sadly sheared my 3rd gears. Hope to get her fixed tomorrow and aim for that 37hp
Glad to hear it's going so well, did you try this cylinder on a less modified setup before?
I guess I'm asking what the new intake location adds to the power on it's own? Looks like that gear gave its all!! danielbrucee wrote: ...but downside is at higher revs the reed petals sometimes dont have time to close completely... |
danielbrucee wrote: The whole principle of the intake is allowing fuel and air mixture into the engine at an calculated time and holding pressure in the crankcase. Technically a rotary valve system is more optimal as throughout all the revs the timing will never change but vespas design is flawed in that it often leaks and gets worse over time. A reed valve set up keeps a better seal, lasts longer, no need for calculating intake timing, but downside is at higher revs the reed petals sometimes dont have time to close completely but overall you will get a way more responsive engine throughout all revs compared to a standard set up. What I mean is, that modified reed intake you did which looks like typical GP or Sport bike, what are the benefits of it? correct me if I am wrong, judging by the reed size, it doesn't differ much with the normal manifold. |
Youre able to use bigger reeds, for example compared to a malossi reed id say its almost twice the size. Also people say the closer to the block the better, it also gives u more room to play with how much fuel u divide into going towards the crankshaft and how much you direct to the engine. I honestly have no idea whats an ideal ratio i guess i just got lucky and it worked well.
Ginch wrote: Glad to hear it's going so well, did you try this cylinder on a less modified setup before? I guess I'm asking what the new intake location adds to the power on it's own? Looks like that gear gave its all!! I feel like when they're talking about reeds at higher revs, they don't mean Vespa high revs. Some of these bikes are only getting on the pipe at the point where a Vespa is into over rev. |
danielbrucee wrote: ...gives u more room to play with how much fuel u divide into going towards the crankshaft and how much you direct to the engine... If it was possible to charge the cylinder directly without going into the crankcase first, there would be no need for transfer ports. Or case volume. Just a need for separate crank lubrication. danielbrucee wrote: Ive always had a reed valve set up... I was reading something just yesterday about the intake distance and volume, saying that the lower the volume the greater the dependency on the exhaust to make the power. Which perhaps explains the Vespa and box exhaust relationship? |
Ginch wrote: I think this is correct - all the charge from the carb must go into the crankcase first for primary compression, before being forced up through the transfers into the cylinder. If it was possible to charge the cylinder directly without going into the crankcase first, there would be no need for transfer ports. Or case volume. Just a need for separate crank lubrication. Was the old one a similar modified case like this? Or the more common reed location where the rotary vale normally is? Just wondered exactly what effect your new reed location had on it's own? I was reading something just yesterday about the intake distance and volume, saying that the lower the volume the greater the dependency on the exhaust to make the power. Which perhaps explains the Vespa and box exhaust relationship? |
Interesting! I guess you could space your reed out pretty easily to see the effects of more and less volume. Cool project.
