@jayn avatar
05 Px150, 74 primavera 125, Honda super cub
@jayn avatar
I want to charge my lithium ion battery with the correct regulator/rectifier. From what I've read it's a big no no to charge it from a stock reg/rec. Has anyone found a proper one to use? Im running brake lights and sip speedo off ac stator and headlights and horn off lithium battery.
@rikko avatar
LML Vespa 150N
@rikko avatar
LML Vespa 150N
What are you trying to hook up, any specs?
@aiosi avatar
@aiosi avatar
Which scooter are you talking about?
I've been running a lithium battery on my '05 for about 4 years now with no bad effects that I am aware of.
@bajarob avatar
@bajarob avatar
What battery are you thinking about? I'm rocking an EarthEx in the Malaguti. If it's an auto battery, you're golden. If you try to use a battery for RC cars or planes, it won't work.
@rikko avatar
LML Vespa 150N
@rikko avatar
LML Vespa 150N
As BajaRob said, you can't use the RC battery. That's because they have external BMS, typically in a charger. Car lithium based batteries have internal BMS, so they can work on pretty much any reg/rec.
@ginch avatar
@ginch avatar
Many of the smaller 12V LiFePO4 batteries do come with the BMS and are often rated at 14.6V for charging I noticed. That does fit in with the typical output from a regulator. My understanding is the BMS protects it from overcharging anyway?
I'm interested to fit one basically to stop my SIP speedo from turning off at idle. Same deal with indicators.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Those EarthX batteries look nice.
Now that I have the Vape, I'm on a search for a battery. I want something tiny. It only needs to feed the lights. Any suggestions?
@bajarob avatar
@bajarob avatar
Im using the EarthX ETZ5G. Love it and I'm putting the same one in the GS. Weighs just over a pound.
I tried running a lithium motorcycle battery in my Stella, one of the standard brands at Batteries Plus. Very small and light. I run the same battery successfully in my 1976 moto guzzi, which throws out 14.6 volts from the alternator. But the Stella charging system wasn't up to snuff and the battery would slowly die. And once the lithium battery is dead, it's ruined and you have to buy a new one, they don't take charge if fully drained. I killed two of them with the Stella, a $200 mistake.
@rikko avatar
LML Vespa 150N
@rikko avatar
LML Vespa 150N
Why didn't a regular battery solve that problem?
@ginch avatar
@ginch avatar
It does. I use an SLA which are cheap but give up after a while. Interested in the Lifepo4 because they're so much smaller. My battery is tucked in behind the tank, it's a very tight fit. The Lifepo4 would fit further into the cavity that otherwise only has my sip speedo black box in it.
@jayn avatar
@jayn avatar
The life PO4 battery I have does have built in BMS but in the product details it says " please kindly use ONLY LiFePO4 dedicated charger rated around 14V)". An old reg/reg certainly is not that.
@jimvanmorrissey avatar
Vespa PX200
Vespa PX200
I run a Landport LFP9 paired with my Vape, wired up to everything: horn, LED headlight, turn signals, tail lights, koso tachometer, SIP tacho karacho speedo, USB charger. This is a combination that I can confirm works, and has worked for 6000km+. It charges fully up to 13 point some odd volts after about an hour's running.
But it's not perfect: if I have the headlight on full beam for more than +-15 hours continuously, it does slowly drain the battery below 12 volts. Switching to daytime running light for a couple hours charges it back up.
I like this Landport battery because it's a bit shorter than the standard YB9 size and the terminals don't glance off the spare tire rim when removing the tire.
A previous, cheaper, crappy LifePo4 battery I tried didn't have a BMS that was up to the task and died after maybe 1000km. It can be an expensive experiment.
⚠️ Last edited by JimVanMorrissey on UTC; edited 1 time
@ginch avatar
@ginch avatar
JimVanMorrissey wrote:
...if I have the headlight on full beam for more than +-15 hours continuously, it does slowly drain the battery below 12 volts. Switching to daytime running light for a couple hours charges it back up.
Wha? emoticon When was the last time you rode for 17 hours sraight!?
Is this one used as a starting battery?
Vespa PX200
Vespa PX200
Heh, haven't done that more than once or twice. But just leaving the full beam on constantly over multiple rides will eventually drain my setup. Bit of a shortcoming. I feel that if the Vape put out just 5 more watts it wouldn't be the case.
Also -- no electric starter on this bike.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Wait … is this battery really made by a company called "Fuk U AI"?
@utahusker avatar
2024 GTS 300 SuperSport, 1980 P125X, 1974 V90
@utahusker avatar
You beat me to it.
@jayn avatar
@jayn avatar
Yup. That's the battery I got. I have been plugging it to a charger about once a week. So far so good. Would be nice to find an appropriate reg/rec though.
@charlieman22 avatar
Nedminder
Nedminder
I'm running the battery below.
I have a ton of lights strung to it.
2 brake lights.
Two headlights.
2 Brake and tail.
Some orange glowing LEDs under the sidecar…
It may sound overburdened and distasteful, but you'd only be half right.
The Vape has charged it without problem. I leave the lights on sometimes if I forget/ or want to be seen.
It's been durable and a good performer for me.
I did buy a cheap Amazon charger made to charge it just in case - but it's been more than ok.
I think they told me if I run it flat it will be no good anymore, but I can't recall the details. They are a SoCal company. This was the battery they recommended.
Charger: $30 on Amazon.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Great info, thx.
Btw, love the Noco Genius 1. It's a workhorse. True story: had it hooked up to the battery in the back of my wagon for an overnight charge, forgot about it, and drove off the next morning with it still connected. Dragged it half a mile down the street like a can on the back of a newlyweds' car. Still works perfectly!
1979 Vespa Primavera ET3 M200
Holy smokes no wonder the scoot is so top heavy with a 12lb battery and fuel tank sitting up so high!
I'm looking at replacing the agm batt with an antigravity lithium battery. 10lbs lighter and half-size as original...
The antigravity rep said the voltage regulator needs to be a solid-state type for these batteries. A search for "vape r102-3 regulator" that is on the scoot says it's not solid-state. Any recommendations for converting to lithium battery?
https://antigravitybatteries.com/products/starter-batteries/restart-oem/atz5-x/
AG batts are great, haven't had any issues with them on my other bikes and they last long time.
@ginch avatar
@ginch avatar
You don't have electric start on this do you? If not then all you need is maybe a 5ah LiPo. Chandlerman uses them on a couple of his. I use a 2ah alarm battery that I'll replace with LiPo when it dies.
No electric start. The battery I'm looking at is
5 Amp Hours (PbEq)/ 2.4Ah (Actual)/ 31Wh do you know if that would work with the r102-3 vape regulator?
Thanks again!!!
@ginch avatar
@ginch avatar
I don't know about your battery, but my $20 alarm battery is charged off the same regulator and works fine. I have a manual switch to connect the battery into the system otherwise it goes flat pretty quickly.
Prior to the battery - fitted thanks to the sip speedo turning itself off at low revs - I ran all DC with no battery and that worked well too.
Chandlerman's LiPo batteries are tiny and have inbuilt bms (battery management system) for protection. Still manual on/off though.
That is nice being able to use a tiny battery! I'll have to do more research on this, the AG battery might be more than I need. I sent AG rep an email asking about the Vape regulator. Will be interesting to hear their response. Having to switch on/off the battery wouldn't be a big deal to me.
Thanks again Ginch!!! 🍻
@geeklion avatar
The Dude
The Dude
@geeklion avatar
I have had an Antigravity LiOn battery in my Vespa for over 5 years. Actually THE SAME battery moved between multiple different Vespas during that time. It still holds a charge at about 14volts. For years using Ducati ignition, and now with Vape. Both systems work fine with the same battery. Tested with on road experience. Dont worry about it and just slap that sucka in there. It works as a battery should.
Every battery I buy will be an Antigravity battery. Worth every cent multiple times over.
Thank you GeekLion! Antigravity batteries FTW! I was glad I did research before purchasing my first lithium battery when they were new. There's a big battery writeup in advrider where I saw AG batteries performance was higher than the others. Excellent CCA values which was perfect for my big bike. I think that was over 15yrs ago and the AG battery I purchased back then is still good. Meanwhile a few of my buddies who purchased batteries from different manufacturer ran into issues with defective batteries or ones that didn't last long. A couple had overheated batteries that almost caught on fire. There was one manufacturer in particular who had a rough start with defective batteries, can't recall the name but it was the white batteries with red print.
Appreciate the feedback, you guys rock! All the best
Just received the new AG battery. What a difference it is and it's going to really help reduce the top-heaviness of my scoot! With fuel and the 12lb battery it is so top-heavy that I have to make sure I'm on engine side when raising/lowering centerstand. Almost flipped me over the bike the first time I lowered it (yes, I'm a lightweight lol).
Here's the answer I received from SIP re' the R102-3 rectifier & lithium batteries. I was surprised they didn't have any recommendations at least. The R102-3 product description does say it handles voltage spikes so I'm just going to add a disconnect switch to battery and not worry about it until I have to.
"Hello! Is the VAPE R102-3 rectifier/voltage regulator a solid-state that is compatible with lithium battery like Antigravity batteries? https://www.sip-scootershop.com/en/product/rectifier-sip-performance-by-vape-r102-138v-dc-ignition-sip-performance-by-vape_51008200?usrc=vape+r102-3+regulator If not, is there a solid state one that you could recommend? Thanks again! Nathan"
"Hello
It isn't designed for this type of battery
We don't have a controller with a monitoring function for batteries like that
Viele Grüße | Best regards
Brickweight on left, Featherweight on the right
@babblefish avatar
Piaggio 2008 MP3 500
@babblefish avatar
My 2008 MP3 500 came with a Antigravity ATX-12-HD lithium battery and so far it's been working fine for the most part. But I'm a little nervous about how long it will last because it is rated at only 8Ah and with cranking over a 500cc engine, heated grips, fog lights, and at times, heated riding gear, I wanted something with more capacity while staying with lithium technology for it's weight to power ratio. Problem is, high capacity lithium batteries are very expensive. The Antigravity battery I have was almost US$300(!). Then I found this:
https://www.aliexpress.us/item/3256805360109149.html?
So I built my own replacement battery. The kit includes a BMS (Battery Management System) controller board that takes care of voltage regulation for charging to prevent overcharging and keep the charge of each cell balanced.
The kit does not include the 18650 Li-ion cells so I bought some from here:
www.batteryhookup.com
Their stock is constantly changing because they deal mainly with surplus so they might not have 18650 cells all the time. I was lucky enough to be able to buy quantity 54 NOS 2,000mAh high discharge current 18650 cells for US$0.72 each. Cells like these normally sell for around US$4.50 each.
Fully populated with 30 cells, the battery I built is rated for a nominal of 12.6V, 20Ah. Should be more than enough for my use. The battery case included a voltmeter, so that's a nice plus. Total cost was a little under US$50. A bargain in my book.
Nickel connection straps spot welded to each cell.
BMS board. Rated for 40 amps.
Battery pack is held in place in the plastic box with high density foam. The wires connecting the pack to the the box terminals are 8 AWG with silicone insulation.
Built-in voltmeter. It is turned on via a touch sensitive switch. Stays on for a few seconds then turns off.
Compared to the Antigravity battery. New battery is the same size and a little heavier, but much lighter than an equivalent AGM battery.
Battery box kit from AliExpress.
@gravelrash2004 avatar
P Series / LML / Motovespa
20Ah.... wow!!
You should make a small batch run
@az_slynch avatar
@az_slynch avatar
Nice work! I have a battery strap welder, so no reason to try this.
wow, I'm impressed! Definitely a bargain if no issues for 3yrs. But sounds like the atx battery has been working fine since you didn't mention it running out of capacity. Thanks for sharing, my big AG battery is overdue to be replaced and being able to save $250 is a no-brainer 👍
@babblefish avatar
@babblefish avatar
The Antigravity battery works fine as long as the engine cooperates and starts immediately. The issues start when it doesn't want to start right away. You only get a handful of tries, then the battery gives up. The "Reset" button on the battery bypasses the low voltage protection for the battery and allows a couple more attempts, but it can permanently damage the battery if used too many times. I'm talking from experience. Hence the desire to install a higher capacity battery. Just for reference, the stock battery in my 150cc scooter is rated for 7A. One amp-hour less than the one for a 500cc engine. A bit too risky for me.
@babblefish avatar
@babblefish avatar
Just wanted to add for anyone wanting to try this. Not all 18650 batteries are the same. Good ones, brand new, non surplus can be quite expensive at US$5.00 - $10.00 per cell. These will have high charge/discharge specs with AH capacities of no more than 3Ah (3000mAh) or so. The cheap ones you see online that advertise 5,000mAh or more are lies. There are no 18650 cells that can produce that many amp-hours into any significant load. Don't fall for the lies.
18650 cells are available in two forms, button top cells (like on a regular alkaline battery) and flat top cells. You want the flat top cells.
Also, some 18650 cells come with built-in protection circuitry. Don't get those. They can sometimes cutoff the power under momentary high discharge loads, like when starting an engine.
Small spot welders can be fairly inexpensive. You don't need anything industrial rated. Mine works with a couple of 7200mAh 3-cell LiPo battery packs wired in parallel. You could also use a 12V car battery. I got mine from Aliexpress, but they're available from other places too, such as Amazon. And for a little more money, spot welders with their own built-in rechargeable batteries are available.
A good source for used quality cells are dead power tool batteries. These batteries usually die from either one battery cell in the pack failing or the BMS failing. The rest of the cells are usually still good and usable. A good example is Milwaukee M18 battery packs. Many times when one of these packs refuse to take a charge it's because one or more cells failed and even if those cells are replaced, the BMS will refuse to allow charging due to the built-in firmware locking everything down.
⚠️ Last edited by babblefish on UTC; edited 1 time
@babblefish avatar
@babblefish avatar
Gravelrash2004 wrote:
20Ah.... wow!!
Haha. I didn't buy enough 18650 cells for that and Batteryhookup is out of stock at the moment.
@babblefish avatar
@babblefish avatar
Last thing (maybe, lol), these battery box kits are available in different sizes, so if you need a smaller or bigger battery, a kit is probably out there.
oh yea the electric start killing the battery Facepalm emoticon ...it's been a long time since I've had that happen. The AG battery with 360 cranking amps made a huge difference over the regular agm battery it replaced on my big bike. Quicker starts with fewer tries.
Now that I think of it, other than fleets of cars burning up on ships, I haven't heard much about lithium battery fires happening in garages lately. But still would pay the extra for known reliability. Thanks again for sharing this very helpful info on how easy it is to put together our own battery packs!
[ Time: 0.0214s ][ Queries: 4 (0.0128s) ][ live ][ 343 ][ ThingOne ]
