Gilera fuoco throttle body( but i guess all MP3's?) has ECU integrated. If you want to exchange it, what does need to be changed too?? Steering lock, steering lock transponder and what about the imobiliser ECU?
Who knows exactly?
Thx
Jo
Who knows exactly? Thx Jo |
Easiest method is to read key codes from original ecu and re-write key codes onto new ecu. The tool needed cost ~200. Pays for itself on the first job.
Thx for the reply, but doesn't answer my question. THrottlebody with ECU, steeringlock, steeringlock sender, and imobiliserunit are all connected. Imobiliserunit is an actuator for the saddle. It is all connected, but everything is sold separatly. So what has to exchanged when u change the ECU???
If you go to dealer they will sell a new ecu/TB. AND a new lockset. Very expensive. ~2000 with labor. I did answer your question. You could send both old and new TB/ECU and I can make your new ecu/tb work with original keys.
I am not really planning on sending 2 throttlebody's to Tampa
The key is unique, ok. The transponder ring is it unique or does it send any keycode tot the ECU? ECU is not unique but written with the keycode. The immobiliserunit, is that unique? Or does it receive any keycode that is written in the ECU? That's my question. Thx Jo |
2007 MP3 250ie / 2022 MP3 500HPE SA [Bad Ass Edition]
Posts: 562 Location: CCS-Vzla |
FonsSpons wrote: I am not really planning on sending 2 throttlebody's to Tampa The key is unique, ok. The transponder ring is it unique or does it send any keycode tot the ECU? ECU is not unique but written with the keycode. The immobiliserunit, is that unique? Or does it receive any keycode that is written in the ECU? That's my question. Thx Jo - The immobilizer is married to the ECU (as far as my knowledge goes), so if you change the ECU need to married it again using some as PADS |
2019 GTS 300 HPE w Malossi
Posts: 9513 Location: Batmania aka Melbourne, Aus |
If it's one of those magneti marelli MIU units that are combined ECU + throttle body then there is no separate immo unit (at least not on any of the vespas that use that ecu/tb).
I've replaced mine on my gts. With a new ecu/tb I simply installed it then used my existing keys in sequence (as described in the workshop manual) to 'teach' the ecu the key codes. perfect. With a 2nd hand ecu I'd suggest using guzzidiag to read the eeprom of the replacement ecu and 'zero out' the keys (replace with 0xff) then write that eeprom back again. then you can install and teach it new keys just like with a brand new ecu. |
Ok, so it seems buying a secondhand throttle/ecu is not going to help solve my problem. I have a 2014 Gilera Fuoco with intermittend coldstart problems. Sometimes it doesn,t start. It is related to environmental conditions. Unable to reproduce the fault. Tried starting it with cooled down coolant temp sensor, cooled down exterior temp sensor. Valve clearance is fine, ignition is fine. I guess it is the mapping. I can read the ECU with IAWdiag and JPdiag. But the real problem seems to be finding the right .xdffile for this ECU.
Tried with xdf from IAWdiag but there not to the point. Values all over the place. Oldskulltuning are on holiday, so i'll have to wait to see if they can deliver good xdf. In the mean time, i could still try tampering inlet temp sensor, but fail to find a way to produce extreme cold air for the intake... I hate Italian bikes.... |
I can make you an xdf for free.
Just send me the bin. contact me via pm if you're interested. Ive made many for this family of ecu. eg https://steelbytes.com/vespadocs/BINs%20and%20XDFs/ (Although this i suspect is not the right way to solve your problem) |
Wow, that's a nice collection!
I need to extract a bin from my ECU this weekend then! How come xdf is per Bin? Isn,t xdf just structure, Wouldn,t you expect each ECU family to use same xdf? Just technicaly wondering. Can i send you my bin in a couple of days? Thx Jo outside of throttlebody says :40 miu1.e1 cm78510 6c92+i6m But IAWdiag reads: : CM085503 : 40MIU1HW102 : 00 : 1233GP41 : 0000 : MIU1E4 : B1 0C 00 13 25 : 121050108 : 20 14 09 19 : 6C902+I6H |
FonsSpons wrote: Can i send you my bin in a couple of days? FonsSpons wrote: outside of throttlebody says :40 miu1.e1 cm78510 6c92+i6m But IAWdiag reads: : CM085503 : 40MIU1HW102 : 00 : 1233GP41 : 0000 : MIU1E4 : B1 0C 00 13 25 : 121050108 : 20 14 09 19 : 6C902+I6H CM085503 is MP3 500 2007-2013. CM78510 is an incomplete part number. Did you mean CM078510 which is for an MP3 400? 1233GP41 This is the version of code + maps. This is correct for the MP3 500, see https://manuals.wotmeworry.org.uk/Piaggio/Piaggio%20MP3/MP3%20500/fuoco_500_map_update_2014_11659.pdf Is this bike second hand? Has someone been messing with it? That mismatched part number makes me wonder if someone took and ECU from a MP3 400 and put the MP3 500 bin on it. No necessarily a bad thing if they are both 40mm. FonsSpons wrote: How come xdf is per Bin? Isn,t xdf just structure, Wouldn,t you expect each ECU family to use same xdf? Just technicaly wondering. |
Outside code is CM078510. I typed that wrong.
As far as i could find out is that the outside number is the part number, not necessarily the mapping code... I completely freaked out, even checked engine number to make sure i wasn't driving around on a MP3 400 thinking it was a Gilera 500. But it is a Gilera 500 engine. Did someone fiddle with it? I don't know. Anyway the mapping code is the right one. Even has the updated map. Which doesn't contribute to finding the fault since this update is already for enhanced cold start in colder climates. Anyway, i will keep fiddling with it. Will send you a .bin in a couple of days. See if fiddling with the map will help. Could allso be a contact somewhere that is malfunctioning in colder and slightly damper conditions. (I am a motorcycle tech and really good at pinpoiting culprits, but this one is bugging me for months!!!) Thx for the input! |
Posts: 23518 Location: Harriman, Tennessee, Tn |
have you done a deep cleaning of the throttle body?
what spark plugs are you using? have you checked the plug caps for cracks and arcing? what fuel Ron rating are you using? highly doubt the ecu has changed perimeters over time causing cold start issues. other factors have changed. |
old as dirt wrote: have you done a deep cleaning of the throttle body? Yes! Even checked function of iddle stepper. Working fine. what spark plugs are you using? Don't know by hart, but new factory prescribed. have you checked the plug caps for cracks and arcing? No, but this bike runs fine once it started. Only cold startissues when outside and a bit colder. (Weird thing is, it never does this when inside my shop, that, since it's summer has all the doors open, hence same climate conditions as outside... (aaazrgh). But defintly due to temp differences) what fuel Ron rating are you using? Euro95 E10 = RON10 highly doubt the ecu has changed perimeters over time causing cold start issues. other factors have changed. Correct, but bought it with this problem. |
Are you sure the foam air filter isn't overoiled?
And have you replaced the main fuel filter and fuel sock/strainer? |
sbaert wrote: Are you sure the foam air filter isn't overoiled? Foam filter has been replaced with a new one. Filtercase stays clean. Everytime i'm fiddling this get's opened. And have you replaced the main fuel filter and fuel sock/strainer? No, could do that, but have doubts that's the cause, since this bike rides fine and keeps riding fine once started. Allso trying not to be a parts changer. |
Posts: 46417 Location: Pleasant Hill, CA |
jimc wrote: And of the course the perennial "Have you checked the valve clearances?"... |
When it doesn't start, it cranks, runs for 2seconds and dies, every try after that, it runs for 1sec and dies. If fed gas trough the inletube it picks up and runs perfectly. So I believe all sytems are fine, except the mapping. Funny thing is I forced coolant temp sensor below 10°C and it would still fire up fine. I believe there is an inlet temp sensor too, still looking to fool that and see if i can reproduce.
Doubting, need to check with IAWdiag... |
JKJ-FZ6 wrote: Have you checked the fuel pump? Or it could fail when cold (itself) and then works when warmed up, but then it would warm up after a few starting attempts. So then i would be able to start after a couple attempts, is my guess... Also the fact i turns over 1 or 2sec's Could be but doubt it. |
BTW, its not that this is the easiest scooter to work on. I'm used to yamaha's and once u know the order of bodywork it's a jiffy to get them naked. But this gilera, a pain in the butt....
Every scooter i worked on, you open the seat, removed the luggagebox underneath and voila, everything in reach. Gilera....not. |
The fact that it runs for 2 seconds, but runs when you feed fuel directly into the inlet, made me think of the fuel pump. It's easy enough to listen for the whirring sound of the pump when you turn the ignition on.
Should doublecheck, but i believe i already did. Standard procedure, so do it automatically.
But, could be... |
Do a fuelpump volume & pressure test.
Clogged filters will primarily impact pump volume while a weak will impact pressure |
Just noticed in a dump from Guzzidiag that TPS is at 3,9 where as it is expected a TPS at 3,5. I will doublecheck, but pretty sure i didn,t touch the throttle and damn sure I have no cable issues and throttle is at minimum on iddle.
Thx Jo |
TPS was 3.9 on idle. Fixed to 3.5 as expected by the ECUmap. Impression it did pick up better on the throttle (could be an enthusiasm misinterpretation...)
I hope for a solved problem tomorrow morning. Jo |
XDF for you
https://www.steelbytes.com/vespadocs/BINs%20and%20XDFs/CM085503_1233GP41_MP3500MIU1_Steelbytes.xdf I see you modified *some* tps scales ... Hmm. |
SteelBytes wrote: XDF for you https://www.steelbytes.com/vespadocs/BINs%20and%20XDFs/CM085503_1233GP41_MP3500MIU1_Steelbytes.xdf I see you modified *some* tps scales ... Hmm. That's the bin I retrieved from the ECU, I did not modify anything. I do see a more detailed parameter structure in your xdf, compared with the xdf for vespa300 from guzzidiag. Is that what you mean? I did have some succes with the Guzzidiag vesp300 xdf, but only with the help of ChatGPT, who found most of the lookup adresses to be 2bytes of. But your xdf is more elaborate. I probably don,t have to change anything, since after setting TPS on idle to 3.5 i didn,t had any starting issues. (For now, it's summer over here) But Still very interesting to study mapping parameters! |
