@chatis avatar
1963 Vespa VBB, 1965 Allstate Cruisaire, 1974 Vespa Super, 1980 Vespa P200, 2003 Stella 2T, 2008 Steall 2T, 2022 Royal Alloy 150 GT
@chatis avatar
Needing some input. I have now got my P200 running and attached the sidecar. There is no adjustment. The scooter leans toward the sidecar, not sure of degrees but toward it. There is no adjustment for toe.
So, taking it for a ride is an education. It seems like it is much harder to ride than it should be.
It is wobbly, the steering shimmies, turning is a workout. And you don't feel like you are in control.
Please share your experiences and advice. The scooter only had 156 miles on it. Maybe because the PO had the same experience and it wasn't fun to ride.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Wouldn't it be awesome if there was like a 100-page thread on this forum where someone actually devoted some serious thought and time to a sidecar set up …
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
@chatis avatar
@chatis avatar
That would be great. How do you suppose you would search for it? What keywords would you use? Would it include how to make adjustments to setups that have no adjustment?
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
sorry, i was being facetious.
charlieman speaks sidecar. His Unicorn is pretty much the state of the art.
Vintage vespa with sidecar (**Now In Technicolor ! **)
i'm sure he would happy to give you some pointers on adjustment.
⚠️ Last edited by SoCalGuy on UTC; edited 1 time
@jedihunter avatar
66 smallstate, 73 primavera,2x 74 rally,79 p200e 64 gl 306 2x 64 vbb, 56 VL3T
@jedihunter avatar
Very few of us have or want experience with a sidecar. Personally I find them not fun to drive, and absolutely terrifying to ride in . But if you gave some specifics( like the manufacturer of the sidecar) and posted some pics of what you've got rolling, some of us would probably dive down the rabbit-hole to help research/problem solve, just because it's interesting!
@chatis avatar
@chatis avatar
Thanks, pics attached. No manual or information on how to set it up. I think there can be some adjustment on the torsion bar but no idea how to do it or what I should aim for.
@chatis avatar
@chatis avatar
Update....
Jacked up the sidecar which put the scooter upright. Loosened the two bolts shown above. That is simply clamps around the tube of the torsion bar. Pushed the swingarm down so the wheel touched the ground and tightened the clamp.
Completely different to ride. No longer a workout but more shimmy on the handlebars. And, the sensation of riding with turning the bars with no lean is very unsettling. Definitely something to get used to and gain confidence in.
There must be some fans of these sidecars out there that can share fine tuning of this particular sidecar. And tips on riding with the sidecar. Like feeling like it will go over or you will go over.
@oopsclunkthud avatar
1:3
as designed
1. toe in is adjusted by slop in the mounting holes of side car frame to the scooter floorboards.
2. lean angle is adjusted by adjusting the side car torsion bar link.
slack these two nuts, move it, torque them back down till it's "right"
@chatis avatar
@chatis avatar
The shocks on this particular scooter are original and are pretty soft. My only point of reference or the performance shocks on another P200 that I have that are hard and have virtually no give. If I adjust it so that the scooter is vertical or leaning slightly out with no one in the side car and no one on the scooter it leans out significantly once I get on it. I'm way too fat at £200. Should I replace the shocks. These are original shocks. The scooter's only done 180 miles. Interested to hear others thoughts.
@charlieman22 avatar
Nedminder
Nedminder
jedihunter wrote:
Very few of us have or want experience with a sidecar. Personally I find them not fun to drive, and absolutely terrifying to ride in . ...
Somewhere in my 100 pages there is actually some discussion of sidecars.
You are on the right track for improvement.
I'll assume you are not going to go full hog as I did with customization - but you can make a static side car a whole lot better than what you are experiencing.
It's all in the tuning of the set up.
You have to be a little fearless when it comes to making modifications to allow some adjustments. You can always have the local welder help (modify or fix...)
What follows is a boil down specific to a static set up.
Here are your levers to pull:
1. Toe in toe out. Subtle changes make a big difference. If you can sort out a means to adjust this accurately with just a few degrees each time - you will gain a whole lot.
2. Lean out - this is the opposite of what you had.
Why:
When you accelerate, the forces will pull you to the right.
The lean out fights this a bit and the toe in corrects for it a bit.
When you brake, it will push you to the left. Here you just have to fight it.
Thats why too much toe in or too much left lean will be unpleasant to ride.
To tune:
Pay attention to what side is pushing and pulling on your head set as you open up the throttle. You want about 1-2° of lean out to fight the pull, and maybe 3-5° of toe in. When set correctly, you can open up your throttle pretty aggressively and not feel much pull.
Set the lean out to a degree or two, and then focus on toe in until the pull goes away on acceleration.
How... well - that's the welder or grinder question. You can easily enough slot your holes at the connection point of frame to scooter - but it's a bear to adjust that a few degrees at a time.
You could probably sort out some means to weld a plate on that allowed you to screw in a bolt or the like, to create both lean and toe. If you post some pics of the frame connection - I might be able to suggest.
Finally - a front steering damper can be rigged up and will do wonders for ridding the shimmy when breaking. It's a known thing - search sidecar steering damper.
I have had a few different ones on my set up - not sure the page - but when it was still static - I added one. the one I set up on my headset would work even if it was static - and other guys tend to do one more like what is shown here.
PX200 with Sidecar
So... think about how you can attach it in such a way that you could adjust the toe in with relative ease. the difference of a few degrees can have a huge effect on feel. most don't bother to get them set up right - and that's half of their bad rap. then figure out how to craft a damper. the combo will be game changing - tho I don't recommend 70MPH on a static sidecar...
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
You want to start witt that.
Only thínking of in future maybe fit a sidecar to my BMW R18 made be look for one. And that is a VÉRY stable bike.
Lean to/out is as explained above a bit different on a Vespa combination. Neutral would be a good place to start lean out from.
I see you have two up seat. Best not ride at all with a pillion but névvah evvah with an unloaded sidecar.
If see above, then the pillon seat will be removed.
charlieman22 thanks for sharing your first hand experiences and insight btw. Much appreciated.
@vintage_red_matthew avatar
MV Santa
MV Santa
I had one and it was pretty much undrivable until I rigged up a steering damper on it. I used one from an old VW Beetle and I fabricated my own brackets. One end attached to the leg shield. The other to one of the shock mount bolts. Heim joints at both ends. It worked great and completely eliminated all wobble. I'll try to find pictures but it was a few years ago and I might not be able to find them. I posted it here so if you do a search you should be able to find them.
Another issue I had was it wanted to lift the side car wheel when making a right turn when empty. I would carry a 50# bag of sand when empty and that helped.
I also made a wheel adapter so the car used a Vespa wheel so I only had to carry one spare. Other than the steering damper that was the best thing I did.
You should expect to rapidly go through clutches and rear tires.
After all that it was still a chore to drive. After an hour or so my whole upper body would be sore. Maybe I need to work out more.
If you're starting to get the impression that I didn't care for that is very observant. I wound up selling it after a few months but if you want to do it I will help you with any advice I can.
Good luck.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Quite.
Side note: it makes left handers safer if the bag is put behind the seat.
MV Santa
MV Santa
Here you go.
The art of floating a hack and terrifying your unsuspecting passenger is one of the true joys of side car ownership. One of the few things I miss.
(Pro Level - feigning surprise and terror concurrently with said passenger for an exponential increase in their shock and horror.)
1:3
Birdsnest wrote:
The art of floating a hack and terrifying your unsuspecting passenger is one of the true joys of side car ownership. One of the few thing I miss.
way!
I had a VNB (150 topend) with a California side car and I'd put my niece and nephew in the hack and take them up and down the street in the air. Drifting the hack around left hand corners was almost as fun.
@chatis avatar
@chatis avatar
Thanks Charlieman. I won't be going anywhere near 70 miles an hour with this side car. I'd be very happy if I could be comfortable doing 50 miles an hour.
This particular sidecar model, the California Sidecar Partner, has no toe adjustment whatsoever. People have said that the only way to adjust the toe is with the slop in the mounting holes, like
oopsclunkthud wrote:
indicated. That being said I am certainly open to any ideas that people may have as to how to make this adjustment. You could slot the holes, or at least five of the six holes, in the mounting pad. My concern here is that what could ever prevent it from sliding.
On the lean there is certainly adjustment. I have that by loosening the bolts on the swingarm bracket to the torsion bar. You can adjust the torsion bar to increase or decrease the lean. I have had success with this and been able to ride the scooter with the side car giving completely different performance.
Thanks to all of your input this is my immediate plan forward:
First I'm going to replace the shocks. There is so much travel in the suspension with these shocks that every time you hit a bump the lean angle relative to the side core changes. Sometimes you're leaning into it turning right, and other times you're leaning away from it turning left. I think if I can minimize the travel that would give me a great amount of confidence.
Second I am going to add a damper to the steering similar to the SIP or others where you have the damper between the headset and the upright column (see pic below). I have already ordered the damper from Amazon and will 3D print the brackets to test the setup. I will then have a machine shop fabricate the brackets. (I would likely put this on to my hotted up P200 as well if it works nicely)
I will then adjust the lean to be one to two degrees leaning away from the sidecar With someone sitting on the scooter.
I'm not certain as to how and whether you need to put weight in the side car if there is no passenger. I imagine if there is a passenger it will cause the scoot to lean out more but not significantly so. Especially if the torsion bar tension is higher than the tension in the shocks. Otherwise, the other way around.
I guess you are referring to not riding 3 up with the side car. I don't think many people will be going in the side car, and I never ride two up on the scooter. Actually I think the sidecar is mostly going to be for my dogs.
@vintageredmatthew i will probably use the column damper. Just dont like the look of the damper on the front wheel.
Thanks for your input Vespisti! I hope this threat will provide value to some other people trying to do the same thing I am.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
No, I am referring to that a passenger on the scoot will HÚGELY upset the weight balance to the point of dangerous. On a Vespa combination it is especially bad because the scoot is relatively light. So just a matter of weight balance vs centrifugal force. With a brown near in the chair of a 2WD Ural it will be ok.
@dirtydave avatar
VB1, VBB, VNA, VN1T, VN2T, VSX, P200, VB1T, Li150 S2,Li125 S3 Riverside
@dirtydave avatar
There is a formula to follow, to set up the engineering to achieve optimum ride control and comfort :
@chatis avatar
@chatis avatar
Finally got to measure the toe on the California sidecar. Toe out about 1 degree. So I decided to give me 1 degree in. 5 degrees that was suggested just seems too much. So this is how I did it.
Removed all bolts except one. Moved it with toe in and market the position of the new holes/slots. Cut them out and reinstalled.
Now have 1.5 degrees toe in. Job done. Still strange to ride.
[ Time: 0.0344s ][ Queries: 4 (0.0275s) ][ live ][ 343 ][ ThingOne ]
