I'm sharing some thoughts here.
I see people asking about how to get more power out of their Vespa, better MPG, or other enhancements. I don't have any particular experience with scooters, but decent experience in automotive engineering.
The Vespa, particularly the 2023 plus GTS is highly developed. It delivers a very good mix of fuel economy, high power for city and rural use, and a balance of other performance factors. All of these things require a balance of engineering design across the chassis, components and engine.
So, any improvements to power (or MPG) will require a trade off.
1. Power. There are good videos, particularly out of Germany showing how to get more power or higher top speed out of a GTS. They invariably trade low speed delivery to get a higher top speed, or greater fuel consumption to deliver more power across the range. It's simply physics and engineering.
2. MPG. The only way to improve fuel economy is to reduce power - until we start installing variable valve timing, a turbo and battery hybrid functions into the GTS motor, there's nothing more to be had. And the cost of those is radically increased complexity. This is how our modern hybrid SUV gets better mileage than a little GTS, with all of those things built into a larger package. Yes, there are tweaks, for example compression could be slightly increased to take 100 octane.
Let me digress also, Piaggio recommends 95, by putting in 100 octane in the current engine you do not get more power, in fact you might get less because often ethanol is used to achieve that. Ethanol holds less energy per volume, and the motor is not optimised for the higher compressions that require 100 octane. The only scenario where 100 octane is going to help is if you're riding very hot for long periods (eg two up in Sahara) and need to combat pre-ignition.
And that's it. Want more speed? You'll lose low speed response. Want more power? You'll use more fuel. Want better MPG? Then be prepared to lose power and slow down. Alternatively, you have to radically increase complexity.
The reason I thought to say this is that a good number of the sellers out there are not honestly representing their products. There are plenty of 'more power, higher speed' solutions being sold with the claim of 'no loss' when physically, mechanically that's impossible for the product they're selling. Or they neglect to tell anyone that fuel consumption will go up - which for me is a big issue, already the range on the GTS is woeful for what I like to do. Anyway, noise is not power!
And of course, this is a pretty niche issue. I see occasionally someone being ripped because they had the audacity to think about reengineering their Vespa for power. And the aftermarket community for Vespa is relatively small, mainly focused on cosmetics, because the Vespa is already pretty well optimised for its market.
That all said, I'd love for these innovations to be picked up. I hear that paggio patented a VVT option suitable for scooters. And they already know how to implement a battery hybrid - which sadly they've developed the 310 away from. But with possibly selling only around 20,000 units per year, that sort of development is probably too costly to justify on the GTS. And could it even be done while maintaining reasonable reliability and repairability?
Keen to hear others' thoughts!
