Hi guys,
I have a Liberty with a 50 4t 2v engine (so same as is in the LX from around 2010) and I have been having some weird problems with the starting.
First off, battery is new and is charging nicely, it is at aprox. 13V and while it runs with revs its at 13.8 to 14.5 V so that is not an issue.
I was thinking it might be the relay but, if I bypass it it is still the same. Wires from the battery to the relay and from the relay to the starter dont show any unusual resistance and the terminals on the starter have been cleaned.
It does kinda feel like the bendix is shot, as it helped for a few starts when I leaned the bike over, but after inspecting, the bendix looks good and with the cover off (and spark plug out - we will return to this) the bendix engages and disengages perfectly. It is also only 2 years old.
As bendix is fine I think it might be the starter itself. As mentioned before, when I take the spark plug out, and there is no compression, the starter (and bendix and everything else) engages perfectly and spins the engine fast enough to crank over, but as soon as the plug is back in the sounds are like the starter just cant get it to spin. It spins like 4-5 revolutins and than it gets stuck. After 1 to 3 second pause it spins it again for a few revolutions and stops and so on and on.
Do you think I shoul replace the starter motor itself? It is not an OEM unit anymore (RMS) so I dont think I can rebuilt it, and kinda dont want to just throw money at the problem (I hate it when people just change parts until it eventualy works again).
Other mods include Malossi variator and red filter, SAS and kickstart delete (almost burned down when it cloged the SAS, and the kick start never worked anyway). I suspect the carb might be upjeted but I dont know how much, it does run just slightly rich...
Any thoughts will be enormously apriciated!
And sorry for poor spelling
