Tilt lock issue:
Symptoms:
1. It won't unlock
2. As soon as I turn the ignition on, my horn sounds 4-5 times ( pretty annoying )
3. It is followed by a non-stop beep from the tilt lock
4. The red warning light is on for the tilt lock
5. Doesn't accept throttle
I first tried charging the battery, but it didn't help.
I also tried the small one using a flat-headed screwdriver to turn the little screw on the tilt-lock motor, but it won't move in any way. I tried with slight pressure on the side by tilting the whole bike, I just ended up warping the tip of the screwdriver.
After I got around to removing the parts of the front plastics, i realised that the hydraulic oil container is empty, so im clearly missing the fluid.
My question now is, can I bleed the system without removing the tilt-lock motor, as it appears to be stuck in place and not moving in any direction?
Are there any steps I need to follow to refill the system with fluid again?
Also, for the piece of my neighborhood I wanted to remove the fuse for the horn, but removing the fuse #9 does not stop it from firing each time I turn on the ignition, and to unhook it from the actual horn, I need to remove the bottom plastic, but I would like to avoid that.
Just to state that 2000km ago, I flushed all the fluids and followed the procedure in bleeding the tilt-lock system. Also before it failed, I got a couple of times my horn turning on when i was starting the engine, it was probably somewhat of a sign that I stupidly ignored.
