Vespa LX50-2T
Vespa LX50-2T
I replaced brake pads on ET2. Checking it for MOT I find when front brake is applied there is a clunk. Is it head bearings need tightening? Or what should I check?
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Did it clunk before the pad swap? If no, check your work.
Vespa LX50-2T
Vespa LX50-2T
I am pretty sure it did not clunk before but pads were completely worn out so might not have noticed. The wider bit of the pad spring is at the bottom.
@willo avatar
2005 ET4 150
@willo avatar
2005 ET4 150
Put the bike on the center stand and move the front suspension around and try to reproduce the noise. Check all nuts and bolts on the front suspension and brakes.
@vintagescooterdude avatar
2006 GT200 2009 Genuine Stella
Do you have the right pads, and are the caliper bolts tight? Something is moving for it to make a clunk, and it pretty much has to be the front brakes, suspension, or steering head.
Vespa LX50-2T
Vespa LX50-2T
Thanks for answers. All is now well. I have fitted new headset bearings and checked the two pivot points (they were fine). Lower Headset bearing was rusty and set was too loose. Removal of lower bearing top race required extreme force- a sledgehammer in the end.
MOT now.
[ Time: 0.0084s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
