Greetings,
Starting a new thread here about impact wrenches. Removing the axle nut was a chore, to change out the flat tire I just had last Friday. It would have been a lot easier if I had an impact wrench, and seeing how I am starting to do work on the bike, on my own again (story for another time), it would be nice to have.
A few months ago, I changed the oil and the oil drain plug was on too tight. Rather than strip it, I took it the shop and they used the impact wrench to get it off. So the more I ride, the more use I have for the tool.
I know the axle nut is held on with 80 ft/lbs of torque, I presume any figure north of that for a wrench would work? Some I looked at are 590, 740, 600? What's needed?
All the ones I looked at online were 1/2 inch. Also most wrenches come with sockets, some most of what I would need, some missing the 24 for the axle.
To add an individual socket is 7-10 bucks, so no biggy if I buy a wrench without one that I need.
Also, for the use on the Vespa, deep sockets or shallow?
Thanks for your input.
