VBB
VBB
Hi Modern Vespa community. Does anyone have the paint code for Cushman imported Vespas? I think it was a blueish green originally and I need to get it repainted. 1961 VBB 150. Thanks!
@572 avatar
2004 Honda Helix, 1977 Vespa P200E, 1976 Vespa Rally 200, 1964 Vespa VBB, 1963 Harley-Davidson Topper
@572 avatar
Nope, but if you can find a spot where the paint was protected from oxidation and UV (e.g., under a sticker or the rubber grips), you might be able to use that for a color match. Sherwin Williams allegedly has an optical scanner service for generating paint codes. Some automotive parts places also have such scanners (e.g., NAPA, O'Reilly), but not by me sadly.
Also, just fyi, something I have learned about vintage vehicles is that even if you have a vintage paint code, that doesn't mean anyone still knows how to make it.
@frank_n_stein avatar
Jet 200, P200E (x2), T5
I'm guessing the color they used were the same used for the Italian market?
If yes, the paint code will likely be listed somewhere (vespafarben.de for instance)
These variants were used on ACMA licensed vespas in France:
@chandlerman avatar
Innovator
391 Days Since Last Explosion
Innovator
@chandlerman avatar
This. And those old codes probably aren't in the computer either, and the color matchers are pretty limited, too.
Even at the local PPG dealer I went to, their own vintage color chip books (which I think weren't vintage when printed) weren't in the computer and had to be mixed by hand.
My Cushman VBB was originally that light metallic blue, which is really similar to a blue used on 1970's Honda's.
[ Time: 0.0101s ][ Queries: 4 (0.0034s) ][ live ][ 343 ][ ThingOne ]
