Cosa 200, 946, Vespa 50, Faro Baso Gtv300
Hi. Just thought I'd share my fun with you all. I have had some starting issues ( no starter engagement) on my 2015 Gts300. A little tap on the ecu or open throttle and let it spring back to idle usually got me going but I got inquisitive and dived in to the ecu. My scanner showed the throttle position at idle was all over the place and a metalic 'tap' on it would usually bring it back to under 4 units and it would start. So I uncliped the black plastic cover on the ECU which didn't help much so in deeper I went. Dissolved most of the silicon around the big wiring plug with petrol overnight and found i had to de solder 4 pins to the idle stepper motor then the circuit board came off, the throttle position sensor was a magnetic disc which was floating around all over the place so a dab or 2 of hot glue fixed that. Circuit board back on, resoldered stepper motor pins, some silicone on plug, a quick throttle position reset with the scanner tool and we were up and running, no more start problems. Happy days.
2019 GTS 300 HPE w Malossi
I've destroyed multiple of the newer G4 version of that ECU (yours is the G3). Also it was caused by my TPS coming loose i think. Can't pull that version apart so easily because it's buried in epoxy instead of a removable cover 😭
[ Time: 0.0081s ][ Queries: 3 (0.0024s) ][ live ][ 343 ][ ThingOne ]
