Vespa Gts 300 Supertech (2020)
My bike's setup: Polini (294CC) cylinder, Malossi piston, Malossi front variator, Malossi ventilvar (cooler), Malossi belt, Malossi clutch plate, Sip brand rear sprocket, Iridium spark plug, Malossi air filter, Malossi oil filter, and finally Force Master 3. I live in Antalya, Turkey, which has a hot climate. However, I couldn't make the low, mid, and hard adjustments; the engine doesn't rev up. I was using J Costa before, but I removed it and recently installed the Malossi front variator. There are 16g weights. If anyone has a solution for this setup, I'm looking for support.
2019 GTS 300 HPE w Malossi
Joined: UTC Posts: 9419 Location: Batmania aka Melbourne, Aus
If you're doing this while on the stand, you can't rev unless you turn off the ASR
I'm closing the century, of course
Sevvki wrote: I'm closing the century, of course ? That didn't translate well.
Vespa GTS Supper
Vespa GTS Supper
Your 16g rollers are too heavy for that big-bore kit. They're stalling the engine. Swap them for 10g or 11g rollers to let the engine rev freely.
