2010 GTS 300ie
2010 GTS 300ie
2010 300 GTS ie Electrical Problem Please Help!
I have a 10,000 mile GTS with an electrical issue.
Has been a perfect stock scooter starts and runs / idles well.
After removal and reinstall the glove box assembly I am now experiencing the following electrical issues:
Starter motor switch on handle bar is dead.
Turn signal switch is dead.
Brake light is dead.
Horn is dead.
Observations:
When key is switched on, I can hear the fuel pump run.
Head light comes on, no lo to high beam change.
Rear Tail light comes on but no brake light.
Red imobilizer light flashes.
Glove box fuses check out OK with meter on both legs of fuse.
Comments:
All seem to be related in some way.
I don't read schmatics well.
New, battery, LED Head Light, Horn, front LED turn signals / relay / running light Installed usb, Cetek battery charge port, Auxillary light switch to left knee pad.
All of the above worked when testing prior to reassembly.
Something has gone wrong in reassembly.
I realize that there are numerous variables involved hear and is my own doing.
Have meter tested start switch / kill switch / turn signal switches, all are good.
Should i be testing relays?
Does this information trigger any helpful input from the collective Vespa world knowledge base?
@abner_bjorn avatar
@abner_bjorn avatar
Check fuse #s 4 and 8 before you go any further.
@safis avatar
@safis avatar
Since everything started after working on the glovebox, you probably pinched the loom going to the handlebars upon reinstalling it…
First - why did the glovebox get removed and replaced? An electrical problem?
[ Time: 0.0129s ][ Queries: 3 (0.0031s) ][ live ][ 343 ][ ThingOne ]
