Hi Friends. I am new to vintage Vespas, so asking for a bit of grace here.
I recently got a 1968 VBC with a Scooterworks LML Engine (this scoot was actually bought from Scooterworks in the early 2000s). It has a Spaco SI 20/20 Carb.
The scooter idles and revs cleanly on the stand, but bogs (and quickly dies) when riding, even when I'm just sitting on it and opening the throttle past idle in neutral.
The bog happens around ΒΌ throttle. If I push through to full throttle, it usually recovers and pulls if I keep the RPM up but will die when the revs go down.
This all started after I changed out the float needle and float because of a small leak. After noticing this issue, I quickly switched back to the original needle/float and same issue.
Additional details:
- New spark plug installed
- New air filter installed
- Mixture screw currently around 2 turns out (I've been adjusting to try and fix this)
- Starts easily and idles steadily
- Issue only appears under load, not on the stand. The minute I get it off the stand and sit on it, the bog begins and it will die unless I crank the throttle.
- I've cleaned the jets and fuel tap filter.
- I've reseated the float/pin multiple times.
- Pulling out the choke makes a negligible difference to avoid the cut off.
- I've done my best to follow instructions on adjusting mixture screw and idle. I see small differences with the mixture screw, but nothing that fixes it.
Help (please and thanks)!
