@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
I am working on my first rebuild. It's a 1965 Vespa 50N barn find. It's missing the cylinder and head. I stripped it down, cleaned it and just started tapping the bearings in. I am looking for top end kit recommendations. I do not want to change the gears from 3 to 4 speed, but I would like to get a little more power. I'm thinking maybe 75cc? Can anyone recommend a good cylinder kit for a vintage 2-port small frame engine?
What's your budget and what exactly do you want out of the kit?
That should help the small frame guys help you narrow it down when they come in.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
Budget, $100-300. Comfortable with spending $250 for something bigger than 50cc, if I can get a little more power.
I plan on keeping it a rat scoot. It's my first time doing a project like this, so it's a personal challenge. I don't need it to rip, I'm happy keeping it a 3 speed.
@oopsclunkthud avatar
1:3
I've run the 102 kit on two different 50 specials, but they make more power than the stock 50 gearing can take (clutch slips) and the fix is to also change to the primary gearing from a 90.
I only built both those bikes because I had a perfect condition crank.
I'd just build it as a 125 or larger from the start.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
So, I bought a 70cc top end kit (KT00111) a while ago, but it doesn't fit onto my 1965 V5A1M engine. I was under the impression I could upgrade from a 50cc to a 70cc without having to machine the engine or up the gears. The KT0011 cylynder is a 3 port and I know my engine is a 2 port which also increased my confusion.
My basic goal is to rebuild the engine stock, so I do not have to machine the engine or change the gears. It's my first rebuild and I just want to say I did it.
That being said, if I can upgrade to a higher engine displacement, I would. I'm considering this one as long as I won't have to up the gears, change the crank, etc.:
https://www.scooterwest.com/small-frame-racing-kit-for-vespa-50cc-to-102cc-pinasco-pin-100.html
If it's just easier to keep it stock, I'm leaning towards ordering one of these:
https://www.racingplanetusa.com/vespa-naraku-scooter-parts-50cc-vintage-vespa-cylinder-naraku-384mm-vespa-special-scooters-p-213117-1.html?backcPathco=295&cPath=53920_53365
https://www.racingplanetusa.com/cylinder-50cc-384mm-vespa-special-p-207712-1.html?backcPathco=295&cPath=53920_53365
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
Definitely makes sense to swap out the primary gear for one from a 90. Good tip, thank you. Time to make some decisions.
@az_slynch avatar
@az_slynch avatar
When you mentioned not boring the case, it made me wonder if your engine is one of the first-series engines.
I have a '64 V90 and it has the older block. The spigot for the cylinder is only 56mm on the early engine versus 61mm for the '66-on engines. I don't know if any kits that fit the older block without opening up the spigot to 61mm
Does your crankshaft small end have a needle bearing for the small end, or a bronze bushing? This can also present an issue, as the connecting rod with the bushing is narrower than a needle bearing rod, leaving a big gap between the rod and the piston on the piston pin.
1:3
The other option for the older cases is turn down the spigot of the cylinder. The trick conversion here was to use a 3 port 100 sport cylinder. I may have one, let me take a look.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
I am sure I have a first series V5A engine.
Here are pics of the crank. I have not installed the inner bearing from the 2 piece type yet onto the longer end.
I'm happy if I don't have to do any machining or source other parts if I can find a stock 50cc engine. Again, it's my first rebuild attempt and I just want to be able to say I did it.
@gickspeed avatar
@gickspeed avatar
i have done this conversion twice. Once turning down the cylinder and the other boring the cases to accept the stock diameter of the 100 sport cylinder. better, but i feel the juice is worth the squeeze. my world would just have the stock 50/90 and have another bike or two or three for all other things.
not encouraging one way or another, just my experience.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
Just for more perspective, here is the frame. At this point, I'm just planning on getting it running as a rat scoot. I don't have a title, so I'm not even sure what it will take to get it on the road, but I'm far from all that. Just taking it one step at a time.
@gickspeed avatar
@gickspeed avatar
Ouch. That chassis. That will have to be addressed.
If this is your first Vespa, you may want to think about getting a different bike with a much easier path to having it on the road safe, dependable, and legal.
Food for thought only.
⚠️ Last edited by GickSpeed on UTC; edited 1 time
@safis avatar
@safis avatar
I wouldn't ride that. The rot in the tunnel and floor compromises the structural integrity of the frame. It can easily snap in half. Deal with it first and then worry about the engine...
@gravelrash2004 avatar
P Series / LML / Motovespa
And just for good measure....
Thars a relatively uncommon scooter so well worth the effort to make it live again.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
No, not my first Vespa. I have a Sprint 150 VLB1T with a Veloce engine that is my main headache and source of joy.
I am all about safety first. So, I'm not sure what will happen down the road. I do have friends (and in-laws) that do bodywork when the time comes.
This was basically a barn find that came into my hands for $100. I'm working on it with my dad as a hobby. And I'm just taking it one step at a time. Not looking to do a full restoration at the moment. My main focus right now is getting the engine put back together and getting it running, off the bike.
@gickspeed avatar
@gickspeed avatar
Go for it. I would get a Title first, work on that chassis second, then worry about that engine third. At least, that is how I would do it. There is probably much more rot there than you can see.
Put up a pic of the under side if you can.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
Thank you for the encouragement. My first thought was to see if I can get the engine running at least... I will look into what it takes to get a title and talk to some people about bodywork. I appreciate the advice. I'll keep you posted!
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
Frame is in storage for the winter. I might be able to get in and take a pic, but not until next weekend at the earliest.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
So I purchased this cylinder from Racing Planet thinking it would fit, but it doesn't.
The spigot is too big a diameter to slide on. Using a caliper, I got a 56.8mm diameter on the engine case (shown in pic).
I am really at a loss. If there is anyone out there with a stock, first series V5A1M top end, that will fit my engine case, I will buy it from you.
@gickspeed avatar
@gickspeed avatar
to resolve this, you could take your cases to a machine shop and have it opened up to the diameter of the cylinder. The cylinder would then slip in. Then you you would have to chan your crankshaft to standard 125/et3 type.
The other issue, correct if i am wrong here folks, is once you put that cylinder on, you may have issues accessing your spark plug once the engine is in the bike.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
I get what you are saying and I appreciate the advice. Honestly, I do not want to have to machine anything. I really just want to rebuild it stock and I do not get why so many scooter parts dealers have top end kits that list early Vespa 50 ('65 and earlier) as a match, but they do not fit my engine. It's really maddening! I just want to buy a stock part that will fit. I'm open to DMs from anyone that can help me.
@gickspeed avatar
@gickspeed avatar
yeah, that ain't right. that first series came in a smaller diameter and i don't think anything is available as a "plug & play" in the market.
First Series v90 should work also.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
Thank you for the tip. If anyone can help me out with a first series Vespa 50 (V5A1M), or a first series V90, cylinder/head (top end), please DM me.
@helikiwi avatar
64, 65 and 66 Smallframes and a Sportique
@helikiwi avatar
DR75 with a 90SS head and 19.19 carb. Widen the exhaust port 2mm and 1mm up.
@gickspeed avatar
@gickspeed avatar
explain how to mount the DR75 cylinder to his cases.
@roland87 avatar
@roland87 avatar
This cylinders will fit:
- Piaggio 50cc
- DR 50cc
- DR 75cc
- DR Formula 75cc
- DR 85cc
- Polini 50cc
- Polini 75cc
- Polini 85cc
@az_slynch avatar
@az_slynch avatar
I have a few 1st series small frame cylinder heads, but the only decent cylinder I have is on my '64 engine.
I'd be happy to toss a head in the mail if it helps.
Sealing surfaces were tidied up.
Good fins, had been vapor blasted.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
roland87 wrote:
Thank you! I was looking at SIP earlier on but opted for cheaper options. I trust SIP to have what I need and these links are very helpful.
Now that I have options, I have to decide if I want to keep it 50 or go up to 75 or 85.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
I will keep this in mind. I plan on getting a full kit from SIP, but thank you for posting.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
Conversely, if you are interested in this cylinder kit, DM me. I will give you a good price. I am going to return it. The only thing is the gaskets came a little damaged (but still usable) during shipping (see pic).
@roland87 avatar
@roland87 avatar
If I'd be you and engine is already split - my chose will be 85cc DR or Polini, correct upgear kit, 16.16 carb and better exhaust.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
Thank you for the suggestion. I'm not sure I want to up the gears. This is my first rebuild and I'm looking at it as a personal challenge, not really to get it ripping.
If I do 75cc, would I still have to up the gears?
1:3
you can probably get away with not changing the primary gearing. It's just that to change it later requires taking everything apart again.
The 50 gearing is so low that the clutch can't take the torque. with a 102 kit the clutch slips. with a 75cc you will likely be ok. I'd put a 4 plate clutch with stock spring to give it a fighting chance.
@roland87 avatar
@roland87 avatar
Yes.
I had Polini 75cc with humble 16.10 carb and exhaust. I put there 18/67(3.72) primary and never regretted it.
On the other side I tried PK with same cylinder kit and generally similar setup but with standard primary, IIRC 14/69, with a 16T pinion(4.31). It felt really short. Maybe ok for very short distances but it was terrible to ride across the city.
So yes. Check what primary do you have and, at least, search corresponding pinion if it is possible for early smallframes.
Or threw in 50cc cylinder and forget about all this gearbox headache.
P.S.
I'm a big guy almost 100 kg.
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
I appreciate the detail! As this is my first rebuild and I still have to sort out what I'm doing with the frame, I will probably get the 50cc and save some potential headaches.
For later I think.... part of tje joy of owning and modifying a vespa is the headache tbat will come with ownership 😀
Good luck and plenty of photos as you work on tnis please, we all love photos
@hvspectre avatar
Vespa Sprint 150
@hvspectre avatar
Vespa Sprint 150
Very familiar with headaches without mods! As I get more experience with stock engines, I would like to experiment more if I get my hands on other projects. I will definitely post more pics of this smallframe as I make more headway with the engine and make some decisions on bodywork. Cheers!
[ Time: 0.0263s ][ Queries: 4 (0.0182s) ][ live ][ 343 ][ ThingOne ]
