I got a 2T Yamaha Jog R 05 recently, im looking for a bit extra power at the moment its mostly stock as far as I know except the exhaust and CDI, at the moment I'll get to 40-45 pretty comfortably. Im looking to get a new piston kit 60cc+. I was looking at the Airsal 65cc but heard they might not be the most reliable - does anyone have ideas for me upgrading this moped within a budget?
1964 Vespa GS160, Fuji Rabbit S601, Lambretta LUI, 1958 Vespa VB1
Posts: 347 Location: St. Louis |
There are a lot of forums such as 49cc ProBoards that are more focused on this sort of scooter platform.
That being said I do have an air cooled horizontal Minarelli powered bike that I have enjoyed over the past few years. -The stock 50cc cylinders can actually be fun, but there here are a lot of great 70cc+ kits to choose from, depends on your budget. -An expansion chamber can make a big difference, even on a stock cylinder, as long as you tune the variator correctly. -Aftermarket variators are a good upgrade. I tried a few options and eventually ended up with a Malossi Over Range set-up. -These motors respond well to a bigger carb as long as the new carb is jetted to the bike correctly. There are some pipes that will do well with a 50 or 70cc,so I would do the following in order if I was on a careful budget. 1. Make sure the bike is in good working order (brakes adjusted properly, variator is operating at optimal level, tires inflated properly, carb is tuned properly...) 2. Expansion chamber and variator weights or after market variator 3. 70cc+ kit 4. Bigger Carb Step 3 and 4 could be flipped depending on what size your stock carb is.
Positive
Go for a Polini or Stage6 70cc kit. They're better quality and more reliable than Airsal for tuning. You'll need to match it with a bigger carb and likely upgrade the intake. Just remember, a big bore kit alone without supporting mods can actually make it slower.
I had similar modifications on my Aprilia Rally, the basis was to perfectly match the gasoline mixture so that the engine would not be destroyed, with the modification the speed was 90km/h, consumption was 7 liters. I didn't do it anymore, it became a lot of money, I chose 125 cc.
Positive
Is this a AC or LC Horizontal Minarelli? What exhaust do you currently have and what size is your carb, and what CDI are you running?
jogrzoom wrote: I got a 2T Yamaha Jog R 05 recently, im looking for a bit extra power at the moment its mostly stock as far as I know except the exhaust and CDI, at the moment I'll get to 40-45 pretty comfortably. Im looking to get a new piston kit 60cc+. I was looking at the Airsal 65cc but heard they might not be the most reliable - does anyone have ideas for me upgrading this moped within a budget? |
I put a 65 cm cylinder and piston on a 50 cm Honda Dio. I didn't do anything else, I didn't change anything else, I didn't even get into the carburetor. The scooter got much better dynamics, but the maximum speed didn't change.
What cylinder? 2-stroke or 4-stroke?
I can see this happening if your stock jetting was a little rich and your still running a stock exhaust and airbox. It sounds you may be leaving some potential gains on the table though. If you want more top speed and better acceleration you typically need to pair several upgrades that all work together. Also, most aftermarket cylinders at least need some chamfering and ring gap checked, not doing that and slapping a cylinder on is a recipe for failure. Naturana wrote: I put a 65 cm cylinder and piston on a 50 cm Honda Dio. I didn't do anything else, I didn't change anything else, I didn't even get into the carburetor. The scooter got much better dynamics, but the maximum speed didn't change. |
Declan wrote: What cylinder? 2-stroke or 4-stroke? I can see this happening if your stock jetting was a little rich and your still running a stock exhaust and airbox. It sounds you may be leaving some potential gains on the table though. If you want more top speed and better acceleration you typically need to pair several upgrades that all work together. Also, most aftermarket cylinders at least need some chamfering and ring gap checked, not doing that and slapping a cylinder on is a recipe for failure. |
That is great, but slapping a cylinder on without even checking the jetting is often a recipe for disaster. Not something I would post as sound advice, especially when referring to a completely different motor.
You can run a bigger cylinder with a stock exhaust and carb and see gains. You can run a bigger cylinder with supporting mods and see bigger gains. Neither is right or wrong, but either way you want to be sure that you check ring gap, clean up sharp edges on ports, and tune the carb for maximum performance. |
Iam currently running a polini corsa 70cc kit and a 19mm carb on mine with a yasuni r. Goes like 💩 off a shovel
Posts: 2162 Location: Tucson, AZ |
Love Yasuni pipes. I've had great results with them.
I wish someone would dyno the C10. It clobbers the R, but had the low-end that the C16 lacks. |
