LX 50 4T
LX 50 4T
Hey all.
Troubleshooting my front brakes. I have replaced the master cylinder, brake line, and caliper. I can't seem to bleed the brakes.
Pressure won't build in the lever. Fluid flowing by gravity through the line. I can't seem to get fluid to free flow through the caliper bleed nipple.
Can air get trapped in the caliper?
Any help or guidance is appreciated.
@abner_bjorn avatar
@abner_bjorn avatar
Shut the nipple, be sure the reservoir is full and pump the lever 50 times to build pressure.
@alexanderevan145 avatar
Vespa GTS Supper
Vespa GTS Supper
Yes, air can get trapped in the caliper, especially with a fresh rebuild. The issue is often the orientation. Try removing the caliper and positioning it so the bleed nipple is the highest point. Tap it with a tool to help bubbles rise. Bleed it in that position before remounting. If the master cylinder is brand new, it may also have a large air pocket that needs priming.
LX 50 4T
LX 50 4T
So I've tried pumping the lever slowly, repeatedly, and "50" times. So far, I cannot even get a tiny amount of pressure to build in the Master Cylinder. I removed the caliper and tried bleeding with it in all kinds of positions.
Smacked everything with a rubber mallet as well. I think I'm just going to take it to a shop.
Would it be better if I had one of those handpump bleeders?
@puno avatar
Vespa ET4 125, Vespa GT 200L, Vespa GTS 300
@puno avatar
Pump with the lever and loosen the banjo bolt on the master cylinder while the brake fluid is still there, repeat a few times.
@abner_bjorn avatar
@abner_bjorn avatar
Where did you get the master cylinder from? It sounds defective from where I'm sitting. It's a simple system. You don't need a special tool to do this. Squeeze the lever, open the nipple.
banjo bolt hole clogged? wrong banjo bolt?
@abner_bjorn avatar
@abner_bjorn avatar
No pressure at all, not likely a banjo bolt issue.
LX 50 4T
LX 50 4T
All the parts came from Scooter West. All new banjo bolts and washers. I'll try the banjo by the MC.
@abner_bjorn avatar
@abner_bjorn avatar
Pull the master cylinder and bench test it. Put some brake fluid in it and pump it with your thumb over the outlet. Does it build pressure?
@windmill_john avatar
Liberty 125 Year 2000
It can take hours, but you can be lucky and do it quicker.
Without the MC top on, when you pump, do you see any disturbance in the fluid?
You mentioned hand pump, you can attach a syringe to the bleed nipple and reverse feed; remembering to loosen the nipple, Just be careful as you have fluid in the MC, you don't want brake fluid on paint work.
You have replaced the hose and caliper as well, you could have an air lock and it will take a while.
Reiterating above, I'd reverse bleed with a syringe.
LX 50 4T
LX 50 4T
Thank you all! I tried for days to bleed the front brakes with a syringe. I broke down and bought a hand pump bleeder. I'm sure that helped a bit, but what ultimately worked was pushing fluid up from the caliper bleed valve. My daughter was helping and as I was pushing, she said tons of bubbles were coming out of the MC.
Mind you I had tried this method once before. Not sure what made it work this time. But bottom line, persistence paid off and I now have front brakes!
Thanks again!
[ Time: 0.0170s ][ Queries: 3 (0.0082s) ][ live ][ 343 ][ ThingOne ]
