More a question than an issue..
As you can see from the picture, the tube indicated red goes back to another part of the fuel tank.
The tube indicated green, just vents to the outside world.
I initially would have thought the red one vented out in case you over filled. But, I'm surmising/guessing that the red one operates as some sort of vent/breathing for the tank? And generally you would not fill the tank to the level of the lower green hose.
If this is correct, I can see a lot of people when they fill up, go above the green level and end up with some fuel on the floor.
Added. Of course I could have put these pipes back on the wrong connectors…. I guess this might be my real question…. But I don't think so due to the fact that the bends wouldn't quite line up… maybe!
But then again, I do not recall a pipe going across the top of the sender unit 🙄
