Vespa S
Vespa S
Ciao,
Recently bought a 2009 125cc Vespa S. It has about 73,xxx kilometres and is incredibly slow. Highest speed reached has been 65km-h down hill and I tend to average about 55km/h on flat roads. Facepalm emoticon
I know these aren't quick off the line but something tells me it shouldn't be this slow.
Does anyone have any suggestions and/or things to check? I'm mechanically minded but don't have any experience with scooters.
@naturana avatar
Vespa S 125 2008
@naturana avatar
Vespa S 125 2008
You must check pressure in cylinder. 70000km is not a joke for scooter.
Are you sure it's a 125 and not a 50?
Vespa S
Vespa S
It's been registered as a 125cc so I assumed. I had a 49cc scooter before and would average about 60-65km/h on a flat road.
How can I confirm on a Zaspa ?
Post a picture of the left rear. The transmission cases are the easiest giveaway.
Vespa S
Vespa S
Will do after work.
Is there a VIN decoder online?
My VIN is ZAPM4430200006543
@alexanderevan145 avatar
Vespa GTS Supper
Vespa GTS Supper
At 73k km, it needs a full tune-up. Likely culprit is a worn drive belt and rollers. Clean the carb, replace the spark plug and air filter, and check the brakes aren't dragging. If it's still slow, do a compression test the engine might be tired.
2019 GTS 300 HPE w Malossi
Gaco000 wrote:
Will do after work.
yes.
https://www.vespa.com/en_EN/recall-campaign/
and
https://manuals.vespa.com/
Vespa S
Vespa S
Okay,
Have some photos. So we can confirm 100% it's 125cc ???
Side View
Side View
Top View
Top View
Odometer
Odometer
VIN
VIN
Gaco000 wrote:
Okay,
Yep!
@puno avatar
Vespa ET4 125, Vespa GT 200L, Vespa GTS 300
@puno avatar
There is a screw missing from the carburetor cover, there is a membrane under the cover, it must be well sealed, it may not be the origin of your problem, but I would put the screw there anyway.
Vespa S
Vespa S
Yep, I know about the screw. I went digging there and dropped it.
Some updates
Air box missing screws
Random small hose I don't see connected to anything
Connect loose and aftermarket fuel line used
Inside casing
Inside casing
Belt area
Belt area
Close up of belt 1
Close up of belt 1
Close up belt 2
Close up belt 2
Vespa S
Vespa S
A lot of bolts missing Crying or Very sad emoticon
Any suggestions where to continue looking or what to strip next?
Variator is nosing spinning it with my hand.
Vespa S
Vespa S
Speaking of the diaphragm, I'd the spring meant to be this long? Very difficult to know it's compressed correctly when fitting.
Also, seal looks very big
Side view diaphragm
Side view diaphragm
Top view diaphragm
Top view diaphragm
@puno avatar
@puno avatar
You've already started disassembling it, take off the variator, take apart the clutch, clean everything, check the diameter of the rollers, put on a second belt. Definitely put the oil dipstick back in place, because something will definitely fall into the oil pan .
@fleece avatar
@fleece avatar
Do you know when the valve clearances were last done?
My S suffered with poor running until I got them sorted, however it would still happily do 95kmh
Vespa S
Vespa S
Just bought the Vespa about 1 month ago. Previous owner used to do it himself, younger chap. Said the usual filters, spark plug etc but never mentioned belt or valve clearances.
Maybe a good thing to do whilst I'm there?
On another note, is it worth while upgrading to a more performance oriented variator instead of original ?
@fleece avatar
@fleece avatar
at that mileage, it should be on its 5th or 6th belt (change every 10 to 12k km)
I left the variator as stock on mine, but changed the rollers to Dr. Pulley Sliders 19 x 17mm x 7.5g which gave it a bit more pep off the line.
When it's running nice, it'll sit at around 60mph, which I am more than happy with.
Vespa S
Vespa S
Can anyone confirm that the diaphragm is how it should be?
Vespa S
Vespa S
Got to strip the Vespa a bit more today.
The rollers differently look oval like, but will measure and confirm.
Do all these vespas have this filter fitted like this ?
Clutch 1
Clutch 1
Clutch 2
Clutch 2
Clutch 3
Clutch 3
Clutch 4
Clutch 4
Clutch 5
Clutch 5
Variator
Variator
Spark Plug
Spark Plug
Fuel Filter
Fuel Filter
Is that a fuel pump?
Vespa S
Vespa S
Yep, is that normal or someone added this ?
Some later models had them, yes.
Vespa S
Vespa S
Did a compression test and results were consistent. Around 135psi
Check the intake rubber manifold for cracks while you're in there.
Vespa S
Vespa S
Do we still think the culprit to be the rollers ?
@fleece avatar
@fleece avatar
what did you mean by this?
Vespa S
Vespa S
When I spin it I can feel the bearing, like it's noisy. However, when I pull the assembly off shaft 2-3mm the noise goes away. Not sure if this is normal
Vespa S
Vespa S
Bump.
Any suggestions on Variator Upgrades ?
[ Time: 0.0198s ][ Queries: 4 (0.0126s) ][ live ][ 343 ][ ThingOne ]
