Completely dead, no signs of life at all. Checked battery which is fine at 12.6 volts. All six fuse in glovebox are fine, flicked killed switch several times so where do I start with diagnosing the issue?
Any advice gratefully received
Piaggio MP3 300 Yourban LT 2016, Vespa 125 sport 2013, Piaggio MP3 300 LT 2012, Honda PCX 125i 2012, Vespa ET2 50 2003
Posts: 113 Location: United Kingdom |
Any advice gratefully received |
Primavera 150S (for sale), and GTS 310
Posts: 1216 Location: North Central Connecticut |
Check the battery terminal, and especially the negative cable where it attaches to ground.
Also, the battery can show voltage without being able to provide current. Try monitoring the voltage while you turn the scoot on. |
Check main fuses in battery compartment and all other again with multimeter
Edit: MY13 does not have the main fuse in battery compartment. In that years Main fuse (15A) is located under the pet carrier. |
GermanGTSDriver wrote: Check main fuses in battery compartment and all other again with multimeter Edit: MY13 does not have the main fuse in battery compartment. In that years Main fuse (15A) is located under the pet carrier. |
Olde Rider wrote: Check the battery terminal, and especially the negative cable where it attaches to ground. Also, the battery can show voltage without being able to provide current. Try monitoring the voltage while you turn the scoot on. |
fungomerry wrote: Thanks, I think that on my model gts 125 all the fuses are in the glove box. Cannot see any in the engine compartment or near the battery. I have 2 x 15a fuses in the glove compartment along with 4x 7.5a fuses. I recommend that you take a look at the owner's manual for your vehicle: https://manuals.vespa.com/?lang=EN |
fungomerry wrote: It's a brand new battery |
GermanGTSDriver wrote: It is not unusual for the main fuse to be blown by mistake when installing a new battery. Your statement that no electrical signs of life can be observed at all suggests this. |
fungomerry wrote: Thanks, it was the main fuse that had blown. I am now back to my original problem of engine cutting out whilst riding. Wonder if the main fuse blowing means it is most likely a bad /broken connection somewhere 🤔 |
GermanGTSDriver wrote: Was the total electrical failure after removing/installing the battery? If so, I suspect an error during removal/installation, which happens quite often. Or was the fuse blowing and the resulting total failure of the electrical system unrelated to the battery? |
fungomerry wrote: I had the engine cutting out issues before I changed the battery. I changed the battery and it ran ok but still had the engine cutting out. The main fuse blew during riding so I would say it was unconnected to me changing the battery. |
Posts: 46405 Location: Pleasant Hill, CA |
