2001 GTS Super (white), 2021 GTS Super (yellow), 2013 LX 50, 2009 Genuine Stella 2T, 1986 Honda Helix, 1976 Bianchi Snark moped, 1980 General 5 Star moped
Posts: 937 Location: Powhatan, Virginia |
My 2013 LX 50 4T 4V.would crank but not start. The carb was getting plenty of fuel, so my attention turned to spark. I decided to pull the plug and have a look see. What a freaking nightmare it was to remove the plug. Whoever designed that motor should be shot. The spark plug socket thst comes with the bike was too long and hit the frame when i tried to get it over the plug. I had to grind it down to get it to work. It literally took me close to two hours to remove the plug and yes, it was fouled and the electrode gap was virtually nonexistent. I had no doubt it was the cause of the no start condition. Reinstalling the new plug was an even bigger nightmare. It takes a very small spark plug that goes down into a blind hole. I had to use a short piece of fuel hose to fish the plug down in there. By the sheer grace of god, I got the plug to thread after about an hour of blind fishing. I tightened her down with the modified spark plug socket. It was so tough to thread, I initially thought I had cross threaded the plug, but it turned out to be just fine. To make a long story short, the bike fired right up on the first attempt. I sincerely hope I never have to change that spark plug again in my lifetime. Thanks for letting me vent.
GermanGTSDriver wrote: 🤷🤷🤷 ⚠️ Last edited by Mopedlar on UTC; edited 1 time
Mopedlar wrote: Thanks for posting that video, but trust me, it's not as easy as they make it look in that video. I've been wrenching on vintage mopeds and scooters for over 40 years and I've never come across a spark plug as difficult to service than this one. Also, if you have big hands and fat fingers as I and many other folks do, the job is made even more difficult than if you have girly many hands…..lol. |
GermanGTSDriver wrote: I'm sure you're right that it's fiddly. I've never changed a spark plug on an LX 50 4T myself, but I know it's supposed to be a bit trickier than on a 2T. |
Mopedlar wrote: I sincerely hope I never have to change that spark plug again in my lifetime. Thanks for letting me vent. |
Mopedlar wrote: My 2013 LX 50 4T 4V.would crank but not start. The carb was getting plenty of fuel, so my attention turned to spark. I decided to pull the plug and have a look see. What a freaking nightmare it was to remove the plug. Whoever designed that motor should be shot. The spark plug socket thst comes with the bike was too long and hit the frame when i tried to get it over the plug. I had to grind it down to get it to work. It literally took me close to two hours to remove the plug and yes, it was fouled and the electrode gap was virtually nonexistent. I had no doubt it was the cause of the no start condition. Reinstalling the new plug was an even bigger nightmare. It takes a very small spark plug that goes down into a blind hole. I had to use a short piece of fuel hose to fish the plug down in there. By the sheer grace of god, I got the plug to thread after about an hour of blind fishing. I tightened her down with the modified spark plug socket. It was so tough to thread, I initially thought I had cross threaded the plug, but it turned out to be just fine. To make a long story short, the bike fired right up on the first attempt. I sincerely hope I never have to change that spark plug again in my lifetime. Thanks for letting me vent. |
I have a 2008 LX50 4T and I haven't had much problems with changing sparkplug. The key to doing it is to use the supplied sparkplug socket and the supplied 'screwdriver' to turn the socket. There is no space to use your own socket/ratchet. I've removed the plug a number of times when setting the mixture, and it's possible to do rather easily. Obviously it's a constrained space, but it's do-able. And it's also important that the OEM recommended sparkplug is used
Landy89 wrote: I have a 2008 LX50 4T and I haven't had much problems with changing sparkplug. Another issue I've seen with the 4T4V engine is that the boot often won't actually click down on the spark plug, and that causes intermittent quits. Cutting the end of the rubber boot back about 2-3mm usually solves this problem.
Positive
Motovista wrote: That's likely because it has a different engine than the one in the OPs scooter. Another issue I've seen with the 4T4V engine is that the boot often won't actually click down on the spark plug, and that causes intermittent quits. Cutting the end of the rubber boot back about 2-3mm usually solves this problem. |
