Vespa px 125 efl
Vespa px 125 efl
Hi,need your help please,my px 125 efl overheats when I get to 50 mph,it is fine below that but over 50 the plug gets red hot and the engine stops,could a bent crank or damaged crankshaft bearing be causing the problem
@chandlerman avatar
Innovator
394 Days Since Last Explosion
Innovator
@chandlerman avatar
More likely, it's an air leak due to a failed crankshaft seal.
If you keep riding it like that, you'll eventually trash the whole top end.
How are your mechanical skills? i.e. do you want to tackle this yourself or take it to a mechanic?
Vespa px 125 efl
Vespa px 125 efl
Thank's for replying,my mechanical skills are good,I have no problem fitting a few seal,that's the first thing I will try,top man, thank you
@roland87 avatar
@roland87 avatar
To replace clutch side crankshaft seal you need to split the engine.
Vespa px 125 efl
Vespa px 125 efl
Yeah no problem,i can tackle that and hopefully it will sort the problem out
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
If you search on here, you'll find methods for troubleshooting air leaks before you split the cases unnecessarily.
Vespa px 125 efl
Vespa px 125 efl
Ok,thank you,I wasn't aware of that,I will have a look
Was just about to say the same but you beat me to it.
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I need to write a Wiki page on troubleshooting air leaks...
It really does come up often. So much so that it's my first step to rule out when there's a problem. It's so easy to do to rule an air leak out
@nellyboyo avatar
DS210 TVRT230
@nellyboyo avatar
DS210 TVRT230
I made a lttle manifold up using instrument scrap from ex-work . Also have a selection of brewing bungs for intakes and exhasuts so you can just inject some air and perform a leak down test . Works ok , not perfect but it was free
[ Time: 0.0134s ][ Queries: 3 (0.0067s) ][ live ][ 343 ][ ThingOne ]
