They will see you coming.
The headlight comes with a special proprietary voltage converter, which makes assembly simple and Plug & Play, as well as anti-flicker for the headlight.
The light has two combinations of lights:
Low beam and DRL position;
Low beam, high beam and DRL position.
PRODUCT SHEET
Package content:
Evok Iron Led headlight;
Proprietary voltage converter;
Assembly instructions in Italian, English, French and Spanish
Technical characteristics of the Evok Iron Led complete front light:
12 Volts;
25 Watts;
2.4 Amps;
Up to 7000 Lm of power;
Led 6000K (Cold white light);
112mm overall diameter.
Wall-E is Made in Italy, like your scooter.
Replaces PI293599, PI294277, 293599 294277
