Hello all. I recently did a coolant flush on my 04 GT200. Since then when I start it up, the temp gauge gets to high, whether idle or I'm riding it, and then drops to a more normal level after 5-10 minutes. As the temp rises, the idle starts getting rough and can stall out. I've tried manually bleeding it by disconnecting the hose coming from the carb to the thermostat housing - but just liquid came out, no air. Any thing else I can try?
thanks in advance!
