I replaced the knockoff carb on my 2005 ET4 with an OEM Keihin, and took the opportunity to install a new intake manifold. I couldn't get vacuum to the petcock to get fuel to flow, so digging into the issue I found the brass fitting that connects the two vacuum lines was plugged with what appeared to be glue. A couple minutes with a dental pick to break through and some brass wire to ream out the orifice and I am good to go.
This was a new Piaggio part, purchased in December, 2025. So much for quality control!
Hope this helps somebody.
