https://www.scooter-center.com/en/engine-housing-oem-rotary-valve-inlet-elestart-with-separate-lubrication-vespa-p200e-px200-px200e-motovespa-p200-px200-iris-tx200/p-48697.html
Apparently based on the PX200 EFL design, with some upgrades around the primary drive and the cylinder base...
No word on country of origin, (which usually means you can expect it to be SEA or India). Curious to see if the casting and machining are quality nonetheless. Under 700€, with a separate variant meant for exotic cranks (Quattrini 244 or 62mm)
