Primavera S:
https://vespa.co.id/en/primavera/primaveras
https://www.instagram.com/vespa_indonesiaofficial/reel/DV8NuMwDYG_/
Sprint:
https://vespa.co.id/en/sprint/sprint1
Sprint S:
https://vespa.co.id/en/sprint/sprints https://www.instagram.com/vespa_indonesiaofficial/reel/DV8NYYilN_H/
Sprint Tech:
https://vespa.co.id/en/sprint/sprinttech
https://www.instagram.com/vespa_indonesiaofficial/reel/DV8NAT3FQRe/
Technical Data:
Displacement: 174,1 cc
Max. Power: 11kW / 14,9HP @ 8,250 rpm
Max. Torque: 13.7Nm @ 6,500 rpm
Cooling System: Forced Air
Euro 3 (!!!)
Furthermore, I assume that, for the time being, the engine will be available ONLY in the APAC markets supplied by the Piaggio plant in Vietnam. There is currently NO—and I mean absolutely NO—indication that the engine might soon be available for markets supplied from Pontedera (e.g. Europe, North America).
The biggest sticking point for Western markets is likely to be the Euro 3 classification. Sure, Piaggio sells the same engine in different markets with different Euro standards (different catalytic converters, different control units/software, a second lambda sensor, etc.), but that doesn't seem to be on the table—at least not for Europe at the moment.
⚠️ Last edited by GermanGTSDriver on UTC; edited 1 time
