2015 PX125 thus with cat and with mix pump.
Done just 5k kms.
We went on an all in all 150 km route with no issues. Well almost none. The mix oil started to leak from the fuel tap. Not sure if that is of importance for the later issue.
After lunch again running ok on the way home. We stopped at a road side café.
After this break the engine was seize rock solid. Period.
Kick starter moves freely with clutch pulled in. Scoot roll freely with clutch pulled in.
All solid with clutch engaged.
Still plenty of oil in the tank. Sight glass full.
Have the scoot at my place now.
Suggestions? Can the fuel tap have impeded oil flow??? or is the oil tank 'tap' always open and thus a leak equalling less gravity feed to the pump thus engine?
