RadoR6 wrote:
The dealer was trying to find the cause at the first service back in 2024 and then again last summer at around 1700kms and but couldn't find anything. I was told the steering head bearings are fine and everything is tight and solid. I'm thinking to have the bearings replaced anyway
Do you know if the dealer actually tightened them? Most scoots will need them tightened at least once after bedding in. Replacing them is a big job, not gonna be cheap.
Checks for bearing health: apply front brake and rock the scoot, should be no movement or clunking. Elevate front wheel, should easily fall to the caliper side, rotate checking for roughness.
