MP3 350 Exec 2017
MP3 350 Exec 2017
Hi All,
Does anyone have any instructions on how to remove MP3 ignition assembly, as i can turn on ignition and start MP3, but unable to turn off and have to disconnect battery!!!
So assume that i need to get ignition assembly apart and check electrical contacts and clean or replace!!!
Thanks in anticipation.
Dickz.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
did you try to remove the blackplastic ring sometime it popsout and the the key won't get in far enough
MP3 350 Exec 2017
MP3 350 Exec 2017
No problem with the key fully engaging and turning, just not possible to turn off ignition even with key removed. I have to flick the red kill switch to turn off engine and then disconnect battery.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
remove plastic ring if its 0.5mm off it will do that
[ Time: 0.0073s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
