MP3 350 LT SPORT ABS
Has any one improved the front lighting?. Mine and I guess all mp3's do this thing of turning one side(low beam) off to turn the other(high beam)on. This reduced visabity to other road users seem unsafe especially when in the wet, dark nights. Before I pull the front off and see if i can fit twin 55/65 h4 in and wire to give low and high in both sides.
@dariusz avatar
2007 MP3 250ie / 2022 MP3 500HPE SA [Bad Ass Edition]
@dariusz avatar
Here in the forum exist a lot info about:
- Convert to H4 (there's even a kit made by a Spaniard to do it in facebook)
- Change bulbs to LED (In my case I feel the light never goes where is needed only changing the bulbs, as the reflectors are not do for led)
- More radical approach as the one I do installing led projectors, fantastic final result, but require a lot of time and effort so things are well (you can find my post about the process)
My recommendation is do good search in the forum, is a lot of information about 😉
2015 MP3 500 ie Business
I wish a solution like this would exist
?si=sjx-rH8JHprH236i
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
converted many units to h4 you can glue 4" H4 mirrors in to the oem mirrors/reflectors then you van use the adjustment as stock ther is a topic about here somewhere
But dont use halogen 55/65 it will melt the plastic HID will do that also use Led 35 watt
[ Time: 0.0081s ][ Queries: 3 (0.0023s) ][ live ][ 343 ][ ThingOne ]
