It does WOT, full acceleration, max speed (90kmh+) just fine, no issues, but as soon as I come to a stop, it sometimes stalls. I can hear the rollers rattling around and then it either stalls or idles perfectly.
It also becomes hard to start sometimes, but it eventually does and idles.
If it does idle, it will never stall. It's really whenever I give it gas and it comes back down.
I've checked:
The idle jet - super clean, no issues whatsoever.
Fuel flow - comes out with just a little tap of the kickstarter.
Valves - all within spec, unless they got out of spec in just a few hundred kms.
I've tried spraying some wd40 around the front of the inlet, didn't notice any rpms change and it was covered in the spray.
Could the rollers have something to do with it? I admit I did reuse the ones that were in there. But I don't see how this would happen even on the stand.
Maybe a bad auto enricher?
