After an oil change on the new-to-me MY21 GTS 300 HPE (I have the big 24mm hex-head oil plug with an o-ring), I noticed locktite on the plug threads -- o-oh. Sure enough, although the plug went back in without much trouble, it soon vibrated loose enough to start leaking oil.
At this point, the plug won't stay finger-tight -- it skips out a thread after I rotate it tight with my bare hands. I haven't yet drained the oil and inspected the threads, but given the steel plug (confirmed with a magnet) and female threads being made of ricotta cheese (aluminum), it's pretty clear what probably happened here -- threads on the engine case are likely toast.
As far as I can tell, the options are:
1. Sleeve the broken threads with something like Time Sert or Heli Coil by drilling and tapping a larger opening.
- Is there enough room to enlarge and counter-bore the hole, given the nearby o-ring?
- Is there enough depth on the female threads for an insert?
- Does a simple insert like a Heli Coil stay in place? I'd worry about it slowly moving deeper into the engine after a couple of years of vibration & oil changes.
2. Drill and tap the hole larger, perhaps even using tapered threads.
- Seems like I'd need to machine a custom plug, since there's a recess on the back for the oil filter insert. Seems like a lot of work for a common problem, we would've seen some project reports if this was the proper fix.
- If the plug strips easily, it'll strip again if a future owner / mechanic is heavy handed with the wrench.
3. Seal the plug with some kind of high-temperature oil-safe goop at every oil change and hope for the best. Feels sketchy to me, but mayhap this worked for you?
4. Seal the plug forever with an epoxy like JB Weld, and use another hole for oil changes. Unfortunate, but it's nice to have a back-up plan.
Is there a better way? Your experience here would help a lot, thanks in advance <3
